8700K running hot
Solved by Streetguru,
18 minutes ago, FootGlove said:It was a brand new sealed unit I bought from HK whilst I was there so returning it isnt gonna be viable. I've delidded and used MX4 paste underneath the IHS as I dont want to use LM. The case is an NZXT H510i with two Noctua fans at the front and the stock NZXT fans at the top and rear.
Just take off the side panel and front panel of your case to check what the temperature difference is with more airflow.
You also want the paste under the IHS to be as thin as possible.
