B450 FOR RYZEN 4000???
Solved by TheSLSAMG,
1 minute ago, Redrooster said:I bought the b450 tomahawk because it was the only the best mobo i could squeeze into my budget, I chose to switch to AMD because I wanted an upgrade path.
To be fair, you do have a decent upgrade path. Ryzen 3000 will net you a 15% increase in single-core performance, and you can get higher core counts and clockspeeds.
Featured Topics
davidholzapfel09 ·
Posted in New Builds and Planning3 -
4
7
Gianluca95 ·
Posted in Graphics Cards1 -
5
8
3
2
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
