Is this a reliable power supply?
Go to solution Solved by The Spectator,
After reading every reply i have determined i need to learn more, i will eventually recycle it and invest in a modern Psu, Thank you all for criticizing my judgement and i will keep you all updated in another thread. Thanks!
If you have a Pentium 4 it's probably great!
Otherwise no.
Primary PC:
17 minutes ago, Budddy1 said:
What exactly are you trying to put together?
4 minutes ago, Budddy1 said:
I was planning on using it for a test bench of older computer hardware anywhere from lga 1366 till am3 etc
Do you want to start a house fire? Cause that's how you start a house fire. Seriously, an exploding capacitor is like shrapnel. You can seriously injure yourself with this. Toss it in the trash before you get hurt
Probably just grab a more modern PSU so you don't have any potential issues.
3 hours ago, seon123 said:
Take a closer look on the output table...
12V*18A=216W
Max on 12V: 180W
240W+180W=420W
Max combined: 450W
Who knows what else they might be making up?
No, max of 180W with 12V at 18A is correct. It's because they're anticipating under load the voltage will drop to 10V at 18A = 180W. It's max output of either 12V or 18A, not both at the same time.
You missed the -5V, -12V, and 5VSB.
-5V 1A = 5W
-12V 1A = 12W
5VSB 2.5A = 12.5W
There's your missing 29.5W.
How could you forget about the -12V rail? :P
/sarcasm
