Any effective cooling solution other than water cooling?
NZXT has systems (brackets) so you can mount an AIO (their AIOs of course) to a videocard. Like the Kraken G12 (which doesn't seem to support the 2070, sadly).
That + the waterblocks you mentioned are kind of the only watercooling options for GPU's. In the past there were alternative air coolers too (like the Accelero III) but that has kind of fallen out of fashion.
Adding more airflow into the system is an option too, but you're kind of dependent on your ambient (room) temperatures too.
The temperature of a device is comprised from a couple factors including, but not limited to:
- Ambient temp
- Device temp (some devices just run hotter/cooler)
- Airflow (or lack there of)
With a lower ambient you will experience lower device temps too. With more airflow (or a better cooler.. Whatever) you're just removing heat more efficiently. The GPU/CPU is stll producing as much heat. You're just removing it better.
