Best CPU cooler for R7 3700x
kumigidax
Hi
I currently have the stock cooler for the Ryzen 7 3700x, but I find it a bit too noisy. So I started wondering.. What's a good CPU cooler for under 100$ which might even make small overclocking possible.
CPU cooler's max height is 161mm which makes it difficult to find a proper one (so Dark rock pro 4 won't fit).
4 minutes ago, kumigidax said:
Ryzen 5 3700x,
Ryzen 5 3600X or Ryzen 7 3700X
Dark rock TF would work
Primary PC:
I'm Re satisfied with my NH-U12A, but in my case it still gets to around 80°C under load.
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
What case and ram are you using?
Where are you shopping / located?
Case: Coolermaster Scout 2 advanced
RAM: corsair vengeance lpx
Located: Netherlands
Im using a NH - U12S on a 3600 and getting 61,7 Max temps while gaming, Average is 51,4
The quoted cpu cooler height clearance for the case is actually 162mm which might not mean that the DRP4 may fit but the extra room isn't useless.
Some good options include:
Phantom: https://tweakers.net/pricewatch/887311/gelid-solutions-phantom.html
ARO-M14: https://tweakers.net/pricewatch/1169683/thermalright-aro-m14g-ryzen-edition.html
If you don't mind spending more for something a little better:
LGMRT: https://tweakers.net/pricewatch/581147/thermalright-le-grand-macho-rt.html
NH-D15S: https://tweakers.net/pricewatch/446782/noctua-nh-d15s.html
