This normal pump noise for an AIO?
Solved by xhackforeverxdx,
2 minutes ago, SuperShires said:So I will be doing a PC build in the near future and I have all the parts besides the case (Ncase M1 V6) so I decided to test build it to make sure everything works.
Everything was easy and booted up first time thankfully, my question is about the AIO pump noise. I've attached a video that demonstrates the noise and I'm just wondering is that normal? does it quieten over time and its just that loud because it needs to circulate or something?
Its a Corsair H100i Pro RGB.
Sounds like air bubbels where do u have the radiator make sure its above the pump
