Can someone explain what Arduino is, and how it works? The online website and definitions seem confusing to me.
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/
Arduino is just a simple board with a microcontroller on it. You make a custom firmware for it than then does various kinds of things depending on what you coded it to do. It does not run any desktop-OS or anything -- it's just the firmware you uploaded on it that is running on it and nothing else.
https://linustechtips.com/topic/1086258-arduino/#findComment-12748642
So it's a programmable micro controller I can mess around with basically?
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/#findComment-12748644
Yes.
Aight cool. Can I re circuit it as well? Or am I thinking of.something else?
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/#findComment-12748652
Mess around would be a decent definition.
You can of course make some more serious things, bit it's mainly a learners' tool (for example student to practice embedded systems tech to further their education towards more advanced devices).
You can make a lot fun devices work with an Arduino, including - but if course not limited to - a keyboard, some alarm systems, I've even seen someone on YouTube use an Arduino to control his dust collection system ('I like to make stuff' on YouTube, if you're interested).
The possibilities are near endless, it just depends on what you want to do.
You can also code some simple interactive programs on it if you use something like a LCD display and some buttons.
The only limitation is your imagination and your ability to look up and combine stuff you found online.
Citcuitbending? That can be done with an Arduino, but from what I have seen it's mainly people reiwiring stuff and adding components (e.g. adding a potentiometer to a circuit to control the input to it).
https://linustechtips.com/topic/1086258-arduino/#findComment-12748667
1 minute ago, WereCatf said:
What do you mean with "re circuit"?
Like, be able to use your finger for something, by changing the circuit on the controller
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/#findComment-12748669
Well, yes. You can e.g. add a fingerprint-sensor to it and make it do something depending on whether it recognizes the fingerprint or not. There are approximately a billion different sensors you can use and go wild with the code.
https://linustechtips.com/topic/1086258-arduino/#findComment-12748684
1 minute ago, James Evens said:
Arduino isn't a µC. It is a ecosystem and should be better defined as a IDE and bootloader.
You don't mess around with the dev board you add external circuity to the dev board.
K got.it, thanks
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/#findComment-12748685
By adding sensors and stuff to it, you are changing the overall circuit. I do not think OP meant actually modifying the PCB itself.
https://linustechtips.com/topic/1086258-arduino/#findComment-12748689
@WereCatf @James Evens and @Minibois so basically it's a micro controller I can reprogram to do almost anything? From a keyboard to an alarm system?
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/#findComment-12748690
You can find plenty of such projects on e.g. Youtube that people have done with various Arduino-boards, yes.
https://linustechtips.com/topic/1086258-arduino/#findComment-12748695
Okay makes sense, thanks dude
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/#findComment-12748697
Just now, James Evens said:
Yes.
But be warned that arduino isn't made for complex problems. It is fine for the first step into embedded devices.
That's alright, I'm looking into becoming a hardware engineer, and I heard this is a good first step to use at my age (13)
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1086258-arduino/#findComment-12748701
For sure!
Get your figurative 'feet wet' with an Arduino before designing more complex systems.
You don't become a runner by running a marathon right away, you start out small.
That's basically what an Arduino is, a stepping stone for anyone interested in hardware engineering (or programming).
It may be cool to get a starter kit of sorts, one with an Arduino and some accessories like a breadboard, LCD, maybe some buttons and LEDs and of course some wires to connect it all.
Get yourself a website or book that runs you through some basic first steps to familiarize yourself with the device before trying out some bigger stuff.
Write down some projects you might want to do with it. A project is a great way to find more and more subjects you want to learn about. It constantly gives you a next goal to work towards. There is always something you want to expand your project with
https://linustechtips.com/topic/1086258-arduino/#findComment-12748728
