Making a Desk Drawer Case - Part 2
Part 2
9 members have voted
1. Server Compatibility - Final Round: Assuming equal effort with this just being a dimensional change to the drawer, Is there a reason NOT to have the drawer conform to Rackmount? A standard filing cabinet has a width of ~15" vs 19 for rackmount.
That 4" isn't much, you might as well have that size5
Make the drawer cabinet as small as you can to minimize space and cost, the extra 4" will make a difference to the material cost and then to the end user and isn't worth it4
2. Should I make a monitor mount part of the design or just let someone attach a stand if they want
Don't worry about it, if they want one, they'll find one that clamps to the desk4
Maybe look at standard mounts and see if there's a standard hole size you could leave spots to screw into4
Go all out with the monitor stand. Try and find a versatile stand and work with the company to include it as an option or standard with the highest tier1
3. One cabinet or two?
Cabinet on both sides to make it symmetrical5
Just one side, exactly as you drew in the paint drawing1
Make that an option for the buyer3
4. I have top drawer being the PC case, but what about the bottom drawer?
Put speakers in it2
Leave it empty5
UPS unit6
Other Ideas (only select if you have an idea and actually put it below please)1
5. Power Button Protection - I'm all for the front facing power button aesthetic, but being a father of 4 going on 5, I worry about a kid pressing it on accident (or on purpose)
Not much you can do there without it being impractical or ruining the aesthetic6
Any ideas to protect it (only select if you have an idea and actually put it below please)3
5 kids??!! "Yes, please press F to pay respects to my non existent social life. You all are my only remaining contact with the outside world."5
6. RGB, had to be asked
No RGB please. I'm a hater and I hate everything that's good about this world. I also waive my right to provide any further opinions to any matters relating to aesthetics.3
That first guy is delusional, Of course RGB. EVERYWHERE you can fit it!3
Back center to provide bias lighting behind monitor3
Just a bit around where the PC drawer is3
Around the edges of the desk2
Set some strips down the middle , making a pattern going across the desk1
7. If... no! WHEN I add the rgb, what do I use to diffuse the light?
Diffuse?? *Takes off sunglasses to reveal sunglasses*2
Cloudy Acrylic, cheap and simple (https://www.newegg.com/Product/Product.aspx?Item=N82E16820232498&ignorebbr=1&source=region&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Memory+%28Desktop+Memory%29-_-N82E16820232498&gclid=Cj0KCQjwhuvlBRCeARIsAM720HpmnlpnsGOuL4lyeAxL-MmGUsjzeJZU0WRVhLvjclJpMojCdiuPFqwaAkluEALw_wcB&gclsrc=aw.ds)4
Textured acrylic (https://www.amazon.com/G-Skill-Trident-288-Pin-Desktop-F4-3000C16D-16GTRS/dp/B07LD44DH8/ref=asc_df_B07LD44DH8/?tag=hyprod-20&linkCode=df0&hvadid=319972287270&hvpos=1o2&hvnetw=g&hvrand=15198719645907641308&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009899&hvtargid=pla-652236138467&psc=1)1
Let user choose between 2 and 32
8. Back of the desk - Where the desk meets the wall, should it have a paneling or be open back (panel could potentially offer more space for wire management, but not sure if needed)
Panel (https://www.staples.com/Alera-Valencia-Series-Straight-Front-Desk-Shell-47-1-4w-X-29-1-2d-X-29-1-2h-Espresso/product_ALEVA214830ES?cid=PS:GooglePLAs:ALEVA214830ES&ci_src=17588969&ci_sku=ALEVA214830ES&KPID=ALEVA214830ES&gclid=Cj0KCQjwhuvlBRCeARIsAM720Hr6NBZihSf0j3VEJVTm8_XNpXYyOxDJz1QJ2nP-U_i77sqT8TfUTdgaAs98EALw_wcB)2
Open Back7
9. For any of this, wires will need to make their way from the drawer over to everywhere else.
Have a hole in the side/top of the desk to plug wires through. A bit tight and hard to use, but gets the job done4
Some kind of extensions for the main i/o (display, sound, usb, power) that will be in the back of the drawer or taking a 90 turn to the desktop surface. You can plug into the drawer with it pulled out, then when plugging in, you just access from the back5
10. I believe in simple naming and product schemes, so I don't want a large selection of models. Addon's and choices are one thing, but I only want so many standard option settings
3 options (pure function, a couple whistles, the whole bell tower)3
4 options (pure function, 2 options in the middle with different focuses of features, the whole bell tower6
Another product scheme (only select if you have an idea and actually put it below please)0
