building my own PSU and don't know what parts to choose
11 hours ago, 17030644 said:<snip>
With the questions you're asking, you probably should not be doing any live mains projects. Not only because of the obvious dangers involved, but also because you won't learn much when you blow up the prototype with every little mistake you make. With a low voltage project you can use a current limited bench power supply and keep your prototype relatively safe.
I'd agree with @Curious Pineapple and aim for a buck converter. Check out the TL494 PWM controller. It will handle the PWM generation and most of the loop (might require extra external frequency compensation). You can then design your own synchronous output stage with 2 MOSFETS and a half bridge gate driver. I'm particularly fond of the MIC4605 with automatic dead time control and a low price tag. Read up about MOSFET theory to be able to pick the right parts for your requirements. You can't just haphazardly pick random MOSFETS like you were doing. Other things to look out for are inductor selection (TI has some nice appnotes about this) and proper power supply decoupling. Board layout is absolutely critical or the thing will ring like a bell. Learn what the 2 main current loops in a buck converter are so you can figure out where there's large dI/dt's so you can design the PCB accordingly. Don't try to build any of this on breadboard or prototype board, go straight to manufactured PCB.
Then you'll need equipment like a current limited bench power supply and a oscilloscope (a real one, not a toy ebay kit). Check out Siglent and Rigol for affordable but decent low end DSO's. Or find an older second hand analog scope, there seem to be some nice cheap Hameg's out there lately. If you're not prepared to make this investment then forget about the project, you can't measure and troubleshoot something like this with a plain multi-meter, you need to be able to see your PWM signals, ripple, etc... It'll also teach you proper probing techniques because scoping a buck converter will show the naive technician lot's of ghosts.
Relevant reading:
http://www.ti.com/lit/an/slva001e/slva001e.pdf
http://www.ti.com/lit/an/slva477b/slva477b.pdf
http://www.ti.com/lit/an/slyt670/slyt670.pdf
http://ww1.microchip.com/downloads/en/AppNotes/00799b.pdf
