I bought a 9900k and a Asus prime z390 motherboard. I’m currently having issues with the CPU’s clock speed, at idle it’s stays at 4.8ghz but as soon as I stress it in games or cinbench the clock speed goes to between 3.6ghz and 4.1ghz
anyone know how to resolve this issue
https://linustechtips.com/topic/1050261-9900k-issues/
Most likely VRM thermal throttling. Get a fan, blow on the motherboard, and see if it runs faster.
Desktop benching:
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12442751
3 minutes ago, KhakiHat said:
When the GHz are dropping while in use, do the thermals change at all?
In some games it's possible that the CPU usage is reduced because of the load bearing more on the GPU.
Thermal drops down a lot, it even happens in prime95 and aida64 the max temp is normally always below 80c. I’m tempted to take motherboard back as all the gear is only 3 days old
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12442764
That's one of the worst Z390 MB's you can buy.
Need a new MB for sure, higher end for a 9900K.
Something in Tier A, no less than that.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12442776
1 minute ago, adambruzz said:
Should I try to return the board ?
Yeah, you need a new MB if you want it work like it should.
Better quality/Higher End than the POS you have now.
Any AORUS Z390 MB will do, Master, Ultra, Pro, Elite....
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12442796
8 minutes ago, adambruzz said:
They already have a fan moving air over them, I’m tempted to take the board back and say it’s defective
over them isn't enough, you literally need a fan blowing air straight into the VRM heatsink.
definitely and buy something else.
Desktop benching:
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12442801
In the meantime -- can you go into your BIOS and increase any voltage allowances?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12442849
it could be clamped to 95w in bios, notice how it throttles to exactly 95w, so see if there's a setting in bios you can turn off. Though i would not run 150w on that motherboard anyway.
You can either return the motherboard and buy any gigabyte board above the gaming x. or you can settle for 4.5ghz avx at 95w, but in that case might as well have gotten a 2700x.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12442911
2 hours ago, adambruzz said:
Gigabyte S1151 ATX Z390 AORUS Pro WIFI DDR4 Motherboard he good ?
Yes, that will do it. :)
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12443283
5 hours ago, adambruzz said:
Just installed it, cpu runs like a champ now
That was fast... ?
Guess you got it locally?
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12444648
This was your issue
This was your solution
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12444676
10 minutes ago, Princess Cadence said:
This was your issue
Yeah, people have to very careful what they buy now with the Z390 MB's and totally completely ignore the budget gurus.
The lower end budget models just plain suck period, especially for the 9900K and 9700K.
Some could get away with the lower end Z370 boards and the 8700K depending.
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12444697
Yeah local store haha, now gotta shop around for a better aio runs full stock speeds at 80c its a Corsair h100i about 3 years old, what’s the best on the market atm
Dunno, I don't use AIO's.
Running a NH D15 with my 9900K at 5 GHz on all cores at 1.30V with no problems.
It will do 5.1 GHz at 1.33V and 5.2 at 1.38V, but I run it at 5 Ghz.
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12446179
47 minutes ago, adambruzz said:
What’s your temps like ?
58C 60ish in gaming etc at 5.0, slightly higher at 5.1.
https://linustechtips.com/topic/1050261-9900k-issues/#findComment-12446483
