shit storm of frame drops and freezing
Solved by Tristerin,
Mechanical Drive trying to drum up 2k textures? Sounds like the issue.
If you are running at ultra settings, and turn around...and get lag...its because these new sprites introduced aren't loaded up on the GPU (just giving an example very basically) so the HDD has to find the file, and load it to the VRAM which in turn is our waiting period.
Turn down your graphics, see if that fixes the problem. If it does, I bet its a storage issue.
Its NOT a RAM issue with Ryzen lol. Unless its a RAM issue, and nothing to do with Ryzen.
