I am starting a new project and thought I would ask the LTT Forms before I got too deep in the project for any tips, thoughts, and general advice.
So Here is the project. I am building a pc for Gaming!!! and video transcoding from Blueray/DVD format to MKV for Plex & Video Station on my Synology.
I am away from home a lot and would like to be able to remote into my computer at my leisure. to check in on the transcoding and a couple other odds and ends.
The only problem is Wake on LAN can be flakey at best and doesn't work if the computer is shut down. and i want to be able to let my computer go to sleep to save power.
that being said I am trying to find a solution that will look better than sticking MicroBot Push to the front of the machine!
I will probably end up with a relay inside of the machine, but I need to figure out what controller to use and how to set it up to be remotely tripped. your ideas and thoughts are welcome!
https://linustechtips.com/topic/1023117-remote-power-button-cool-or-dumb/
Some motherboards can be set to turn on at set times even without user input. I feel like thats far more practical.
If you havent bought your mobo yet, make sure to search one out with this feature.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Hook up a Raspberry Pi to the internet and have its I/O pins connected to the PWR pins of the front panel header on the motherboard. Run a listener on the Raspberry Pi so when you send it a packet, it trips the PWR pins on the PC.
More info at https://electronics.stackexchange.com/questions/59652/pc-start-button-effect-from-electrical-point-of-view
I have looked into Rasberry Pi  a couple years ago. I like this idea. thanks for the tip!
I want something I can power up even if it's in the middle of the night from across the US. thanks for the input!
I agree with the auto on, if needed i'd do a few test runs to make sure it turns on consistently.
As with remote access, honestly i'd use chrome remote desktop, i've been using it for years now and it's very good, only downside is it sets window's aero mode to basic if you're using 7. It can fully control the PC to your liking, just be sure not to send a CTRL+ALT+DEL.
s with sleep, if the rig isn't too power hungry at idle i'd just let it sit on as it shouldn't really effect your electric bill too much, as long as it isn't constantly doing work 24/7 (computers only draw a small fraction of the PSU's max when they aren't doing anything). The raspberry pi idea sounds good as well though if power is a big concern for you.
1 minute ago, Ev The Nerd said:
@Axeoasis I actually use Jump Desktop for my remote client. it works really well and takes up phew resources when running in the background. chrome can be a mem hog if you don't quit it from time to time.
true, if jump desktop works for you then i'd stick with that ?
I did this and made a thread about it:
I guess the pictures got deleted from postimg.  The TLDR: buy a smart outlet for $30 and tap into the relay inside of it.  Using a RaspberryPi or DIY thing is "cool" but it's not smart engineering when you can take something off the shelf and leverage *their* effort and app support and everything.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Some board uses a app that lets you power on/off your PC from your phone.
I know HP has this proprietary hardware features, for their servers, that lets users physically power on and off their computers, remotely even when they're on the other side of the globe. It's called Integrated Lights Out
https://en.wikipedia.org/wiki/HP_Integrated_Lights-Out
Why bother with a relay when you could set UEFI to turn the computer on automatically whenever AC power resumes? Assuming those smart plugs actually physically disconnect the socket from mains.
Reliability.  A relay is electrically "pushing" the button.  That "restart on AC" power I think doesn't work if you do a graceful shutdown too.
I'd definitely do with UEFI to turn the computer on as it's the most reliable way (i used it with my build when i went on a cruise last November for a week), although in the event his board doesn't support it or it's malfunctioning, i'd do the smart plug as they tend to have apps to allow remote control instead of just timers. then you just have to set the bios/uefi to turn on when it's plugged in.
Ohey three days later.
I just tried it. Set my ACPI "On Power Restore" option to "Power On", let it boot to Windows, did a Shut Down, unplugged the computer for 10 seconds, plugged it back in, PC came back on.
https://www.amazon.com/gp/product/B01MQUANS8?pf_rd_p=1581d9f4-062f-453c-b69e-0f3e00ba2652&pf_rd_r=ZKQP3AXAM8BN5MTXJTFX
I have been thinking of something like this, then have Alexa turn my computer on and off.
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
