URGENCY! PC won't post.
Solved by Dixel,
Alright, none of what you guys suggested actually worked. I just did the old "unplug it and plug it back in" method and that did the job. I reseated the GPU and unplugged and plugged in every single power connector. That did the job. Maybe it was the motherboard power connector or the CPU power connector. It clearly wasn't the GPU connector since I tried unplugging and plugging it back in multiple times.
