The i7 6700K and i7 7700K both are still perfectly capable gaming CPUs, specially if you refrain from multi-tasking while gaming.
You can pair them with a GTX 1080 yes, do consider the 1070 Ti if you want to save a buck as it performs much the same after overclock or even the recent released RTX 2070 because it'll give you 1080 performance but let you play around with Ray Tracing when it becomes a real thing.
Personal Desktop":
Luna, the temporary Desktop:
Hi so I currently have a 6700k at 4.2ghz and a 1060. If i upgrade to a 1080 will I be benefited from it or will my CPU bottleneck because I was playing Bo4 multiplayer and gpu usage was around 97 so If i get a 1080 it will go down the gpu usage so I just wanted to know if it would bottleneck.
You're good.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
very rarely, i can think of maybe 2-3 games.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
If you only have a 1080p 60hz display there's no real reason to upgrade your GPU
I have a i7-6700 with a GTX 1080. While there may be a slight bottleneck, it's too small to matter. So for your case, it'll be even less so.
I have a friend running a 1080 SLI with a 3770K
7 minutes ago, Randomizer23 said:
Thanks for all the replies and btw i have a 144hz monitor so thats why
Even for a 1080p 144hz display you can just disable a few settings like shadows or AA to get your fps a lot higher on a 1060.
Also is it a free-sync or g-sync display?
  • 2 weeks later...
So I have a 6700k clocked at 4.2ghz and was wondering when I should upgrade to a better cpu. I game at 1080 but 144hz so I need the extra cpu power. Im scared that in only 1 year my cpu will be a bottleneck to my gtx 1080. Does anyone have thoughts on this?
if your CPU is not bottleknecking your GPU now, it won't next year (granted you don't break your CPU somehow). If you really want to upgrade, nab a Ryzen 7 or get a Ryzen 5 and OC it.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Only upgrade when you're not getting the performance you want. Also, how would the 1080 suddenly br bottlenecked by your CPU? If it doesn't now, not like anything will change about either the graphics card capacity or the CPU capacity.
Primary PC:
PSU tier list
How many watts do I need?
Thats true, thanks guys
It won't bottleneck a 1080 and if you want more frames at 144hz, you just need to overclock your CPU. IPC didn't exactly rise since Skylake for Intel CPUs so upgrading wouldn't be that beneficial at the moment. Stick to it for a year or two more, it's perfectly capable for gaming.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
  • 4 weeks later...
Hi, I have a 6700k and a GTX 1080 and Ive noticed that in some games my GTX 1080 gets held back this is important because I play at 1080p 144hz. I was wondering if i OC my CPU to 4.5ghz will this help the bottleneck? I have never OC'd but Ive watched many videos. My GPU usage is usually around 75 %to 95% so I really need the extra performance. Thanks!
Edit: My CPU usage is around 40% to 60%
Your GPU is likely the culprit. Check the GPU usage since you only have 40% usage on the Cpu side.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
It isnt because I upgraded from a GTX 1060 and im getting a little bit better performance but not what I was expecting.
