How are USB DACs better than sound cards?
I saw logan's video saying sound card aren't worth getting, and to get an external DAC instead, but how exactly? How could a USB DAC be better than a shielded PCIe card? And I don't mean how it sounds, but why a sound card couldn't do the same as a USB DAC, because the only disadvantage I see for sound cards is that they're going to get electronic interference, but shielding helps that. And isn't PCIe superior to USB? If someone could better clear up HOW they're better that'd be great, but don't try and sell me one, I'm not buying an external DAC unless it's for my laptop.
Like I say in the FAQ they don't make much sense anymore unless there's something wrong with your onboard. Everything a soundcard can do, your onboard can do. We can make hay all day about the differences in design, but the real issue with soundcards is they are redundant in 95% of all cases (the remaining case being as an encoder for multi-channel game audio from a console). For people wanting the most ACCURATE sound, I also note the damping factor is bad when the output impedance of most soundcards is above 10 Ohms, but that difference is minuscule compared to the effect of a good pair of headphones anyways.
Components don't mean anything. The overall IMPLEMENTATION of those parts is what really counts!
USB DACs aren't necceasarily better, but the solution for most professional ACCURATE gear is in fact, USB or FIREWIRE or some other sort of external interface that reduces the chances of interference. Not to mention makes it much easier to move when necessary.
EDIT: Also class 1 USB devices need no special drivers in windows, mac, and linux.
