3 minutes ago, EndorOS299 said:
why is it that i've never seen a motherboard with more than 2 cpu's.
Probably because you haven't bothered looking :P
image?p=12051&i=1
Quad-socket motherboards aren't scarce in the server market (which is where you would find the dual socket motherboards anyway).
https://linustechtips.com/topic/937018-more-than-2-cpus/#findComment-11436974
Xeon CPU's support it, Multi CPU motherboards.
Consumer grade it doesnt make sense, its added cost for no additional performance for MOST people.
https://linustechtips.com/topic/937018-more-than-2-cpus/#findComment-11436984
Yep, go look at server products.  4P setups though are pretty sweet.
Use to be the big deal when bigadv in F@H was around.  Know a few chaps that run 2P setups for BOINC still.
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
https://linustechtips.com/topic/937018-more-than-2-cpus/#findComment-11436992
Where have you been looking?
Just search on google you'll get tons of results
Dual CPU was brought to consumer hardware when multi core cpu wasn't a thing yet, since dual core is popular dual cpu isn't practical for home user, they just need a better processor with more cores rather than more cpu (altough that would work too), dual cpu has been always aimed for server market rather than regular home usage.
https://linustechtips.com/topic/937018-more-than-2-cpus/#findComment-11437041
Pcpartpicker wont bring you these multi socket boards, but they are plenty in the server market and used sites like ebay....
Desktop benching:
https://linustechtips.com/topic/937018-more-than-2-cpus/#findComment-11437046
