how many fps would gain with 1180ti, i7-9700k?
saif96
so im planning on gaming in 4K max graphics ones the PG27UQ and new GPU's becomes available so what im planning on getting
Asus 1180ti, 5Ghz i7-9700K and DDR4 3200Ghz how much fps should i expect go get in 4K games like Far cry 5 & Rainbow six? what im guessing is +100fps am i right or wrong? what do you think?
We don't know until they launch and have proper tests done on them.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Well 1180ti is probably as fast as a titan V, so look up titan v 4k benchmarks.
Short answer: nobody knows!
Seriously, NOBODY knows.
Some people at Intel might have a vague expectation of what their future high-end cpu's can do and some people at Nvidia might have a vague idea of what their next high-end graphics might do.
Thing is, nobody knows what that combination might do.
We can speculate and guess but that's not going to give you answers. I mean even if we do know, what's the point if it's still a year away?
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Builds:
It'll probably be a pretty decent card for 4k, but I highly doubt it'll be a "no compromise" card. 100 FPS in FarCry 5 at 4k seems optimistic, especially if you stop to consider consider that is SLI 1080Ti territory.
Gaming Rig
CPU: Intel i7-6850k @ 4.2GHz
GPU: 2x FE GTX 1080Ti
Memory: 16GB PNY Anarchy DDR4 3200MHz
Motherboard: ASRock X99 Extreme 4
Encoding Rig
CPU: Ryzen 7 1700 @ 3.7GHz
GPU: GTX 1050
Memory: 8GB Curcial Ballistix DDR4 2133MHz
Motherboard: Gigabyte AB350M-DS3H
expect around 2x gtx 1075ti performance or maybe 2x 1080. but no where near 2 1080tis
0 FPS but you do get to travel to the future
No idea but the 1180ti won't come out for at least another year. Anyways we have literally no idea. It could be a relatively small improvement, or it could be doubt. We have no way of knowing or even guessing really in terms of the 9700k and 1180ti, both of which are multiple launches away. If I had to guess, 8 core coffee lake and 1180 will be about 20% faster in games than a 1080ti 8700k system. Beyond that, I can't even begin to guess.
  • The 1180 could be a massive 40% increase over the 1080ti
  • Or alternatively the 1180 could be only like 20% faster than the 1080ti.
  • The 1180ti could be a massive 40% leap over the 1180 like the 1080ti was over the 1080
  • Or alternatively the 1180ti could be a more modest 20% increase over the 1180 like the 780ti was over the 780.
When we're looking at launches more than one generation ahead, it's really hard to guess.
  • If we assume best case scenario for both the 1180 and 1180 ti then the 1180ti would be twice as fast as the 1080ti.
  • If we assume the worst case for both the 1180 and 1180ti then the 1180ti would only be about 50% faster than the 1080ti.
  • We could also split the difference and it could be 75% faster than the 1080ti.
The point is that beyond one generation, the differences in each card multiply so what is a 20% difference between each card makes a 50% difference overall. So yeah. We don't actually know.
Main System: EVGA GTX 1080 SC, i7 8700, 16GB DDR4 Corsair LPX 3000mhz CL15, Asus Z370 Prime A, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R5, 2TB Seagate Barracuda, 500gb Samsung 850 Evo
Secondary System: EVGA GTX 780ti SC, i5 3570k @ 4.5ghz, 16gb DDR3 1600mhz, MSI Z77 G43, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R4, 3TB WD Caviar Blue, 250gb Samsung 850 Evo
4 minutes ago, WereCat said:
5FPS with a range of error in my estimation being at least 1000FPS
-995fps Bildresultat för thonk
Builds:
No, no, no. Nvidia will take a new approach with the 1180 where they'll implement time dilation so it will run everything a 1 FPS, but it will speed up your time by 6000% so it looks like you're playing at 60 FPS.
You will age a lot quicker though.
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
