Purchased wrong antennas for wifi card, can I solder?
sauce-c
The title explains it all. I purchased antennas with the wrong connectors for my intel M.2 wifi chip. Can I just cut off the ends and solder the wire directly to each connector on the wifi chip? Any info is greatly appreciated.
Heres what I have to work with.
https://www.amazon.com/Highfine-Wireless-Extension-Bulkhead-Repeater/dp/B01GMBUS8O/ref=sr_1_8?ie=UTF8&qid=1525726584&sr=8-8&keywords=ngff+antenna
https://www.amazon.com/gp/product/B079QH5KW1/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
CPU: Intel Core i7 8700k 3.7Ghz MOBO: AsRock Z370 Extreme4
RAM: Corsair Vengeance (4x4) Storage: Crucial MX300 275Gb | WD Blue 1Tb
GPU: XFX RS RX480 8Gb Case: Corsair 270R PSU: Seasonic Focus+ 750w
Monitors: HP 22cwa | BenQ BL2420PT  Cans: ATH-M50x
1 minute ago, Electronics Wizardy said:
You can, but won't it be easier to just return and get the correct parts and interferrance becomes an issue.
Whats the difference between using a connector and just soldering them?
How are they wrong?
The cables are IPEX and the adapter card uses IPEX cables
Edit:
Or did I miss something obvious? (completely possible xD )
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
There is lots of sheilding on those connectors, and probably not as much in your soldering job. Also that connector is a pain to solder, there are 2 contacts in that little connector.
2 minutes ago, Lurick said:
How are they wrong?
The card has NGFF connectors
EDIT: I think, idk. My research tells me the connectors do not match up and that there is two variations, I happen to have the wrong one.
They are the same thing though, just different names.
I'm pretty sure MHF4 is the contact on the adapter and u.FL and IPEX are the small connectors on the cable that connect to an M.2 NGFF card.
Prior Build Log/PC:
Here is what I found in the comments
-snip-
Ah, I see now. After further digging, which still produces some conflicting results (yay internet) you need an MHF4 connector and those are MHF3 connected cables. They are similar expect in size so that's why I was having such a hard time tracking down everything and telling them apart since I think they are all IPEX style cables, but I digress.
If you search IPEX or u.FL by itself then you get all sorts of garbage which is hard to sift though =/
Prior Build Log/PC:
Just now, Lurick said:
Ah, I see now. After further digging, which still produces some conflicting results (yay internet) you do need an MHF4 connector and those are MHF3 cables. They are similar expect in size so that's why I was having such a hard time tracking down everything and telling them apart since I think they are all IPEX style cables, but I digress.
Okay so I need to order MHF4?
Yes, that, from best I can tell, is going to work with the NGFF cards :)
Unless this is wrong:
http://www.wellshow.com/rf-connectors/mini-connector/ipex-mhf4-connector/
Thank you so much, this has been driving me INSANE.
10 minutes ago, Pangea2017 said:
Unless you want to solder a small coaxial cable no.
i do not suggest this, BTW. you are almost guaranteed to lose your 50 Ohm of impedance.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
After help from @Lurick I ordered some new ones off of amazon, hopefully I will be back up and running Tuesday. Thanks for the help!
