Will a Y splitter work on my mobo's fan header?
robrulz123
Hello all,
I am planning to buy two Coolermaster Sickleflow X's (red led) and a Y splitter as I only have one chassis fan header available. To my knowledge, each of these fans draw 0.35 amps and in total thats .70 amps right? So will my motherboard (Asrock H81M-HDS R2.0) be able to sustain .70 amps from the one chassis fan header through a splitter?
(I just want to make sure I don't fry my motherboard)
Thank you.
The manual for you MB doesn't specify this, but I've not heard of a fan header with less than 1A in any modern motherboard. I'm sure you'll be fine.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
Yes, that's fine. That being said, Sickleflows aren't great and I wouldn't recommend them unless you only want cheap led fans. They're either noisy at high rpm or don't perform well at low rpm.
