psu COOLER MASTER MWE 550, SEASONIC S12Ii-520 or another PSU?
Solved by OrionFOTL,
Well, you can go wrong with the Seasonic one. It's an 8 year old, bottom of the barrel design that shouldn't be used in modern computers anymore, and lacks some important protections.
Your setup with the Ryzen and GTX1060 will consume around 200W under load. Corsair CX450M https://www.chip7.pt/fontes-alimentacao/15645-corsair-fonte-builder-series-cx-v2-450-watt-semi-modular-80-bronce-atx-cp-9020101-eu-CP-9020101-E.html is a much better power supply and will work good. If you want to have something higher quality, get TX550M: https://www.chip7.pt/fontes-alimentacao/25330-enthusiast-series-tx550-watt-modular-power-supply-CP-9020133-E.html
