Posted January 12, 2018 Hello there so i got my new case the 570x and built my pc in it the only issue im having is airflow Which way is the best way? and what is negative pressure that keep popping up in some threads that i have seen This is my current setup i wanted to put the x62 on top but it did not fit so installed them in the front So any suggestions and opinions Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 I say front and back as intakes so your rams get cool air. Top as exhaust. Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64 HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64 HP Envy x360 BP series Intel 8th gen AMD ThreadRipper 2! 5820K & 6800K 3-way SLI mobo support list Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 Usually it goes the other way (front to back), and I assume that's better. QUOTE/TAG ME WHEN REPLYING Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. If I'm wrong, please point it out. I'm always learning & I won't bite. Desktop: Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change Laptop: HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 That is really not the best way. Make your front fans intake and rear and top ones as exhaust. Basically use your AIO fans as intake and top, rear fans as exhaust. CPU: R5 1600 | Motherboard: Gigabyte AX370 Gaming 5 | RAM: Gskill RipjawsV 3200 MHz 2x8 GB Black | Case: Phanteks Eclipse P400 | PSU: EVGA 650 G3 | SSD: Samsung 850 Evo 500 GB | Graphics Card: MSI Armor RX 570 4G OC | Wi-Fi Adapter: Asus USB-N14 | Headset: Arctis 5 | Keyboard: Masterkeys Pro L Cherry MX Red | Mouse: Logitech G402 | Mousepad: Logitech G240 | Monitor: Viewsonic XG2700-4K Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 Author 2 minutes ago, NumLock21 said: I say front and back as intakes so your rams get cool air. Top as exhaust. 2 minutes ago, Nazim Pasa said: That is really not the best way. Make your front fans intake and rear and top ones as exhaust. Basically use your AIO fans as intake and top, rear fans as exhaust. The only problem that i having right now is if i wanted to flip the case fans the other way it wont screw in Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 Keep the front as intake. Since hot air naturally rises, you don't really want to have the tops intaking. I recommend top exhaust, back exhaust, and front intake. print "Hello World!" ("Hello World!") Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 Just now, Meoww said: The only problem that i having right now is if i wanted to flip the case fans the other way it wont screw in What do you mean won't screw in? You can create new threads on both sides of the fan. Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64 HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64 HP Envy x360 BP series Intel 8th gen AMD ThreadRipper 2! 5820K & 6800K 3-way SLI mobo support list Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 This old NCIX video should help out with some of your questions. https://www.youtube.com/watch?v=sh6F2eccMec Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 a good rule of thumb in life in general is: in in the front, out in the back Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 Author 7 minutes ago, NumLock21 said: What do you mean won't screw in? You can create new threads on both sides of the fan. Umm what do u mean by create new threads ? the case fan on one side can be screwed in smoothly but on the other side wont get in the surface on it is like smooth. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 Fan holes usually are smooth when new. The thread is created when you actually start screwing it in. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 I have intake in front and top, exhaust on back and power supply upside down to fan it's heat down. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 Author 5 minutes ago, Captain Chaos said: Fan holes usually are smooth when new. The thread is created when you actually start screwing it in. Ahha thanks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2018 6 minutes ago, Meoww said: Umm what do u mean by create new threads ? the case fan on one side can be screwed in smoothly but on the other side wont get in the surface on it is like smooth. The threads are created by the screws. On the smooth side, you have to use the screw to create new threads, to secure your fans. Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64 HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64 HP Envy x360 BP series Intel 8th gen AMD ThreadRipper 2! 5820K & 6800K 3-way SLI mobo support list Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2018 And as a rule of thumb, you should have more intake than outtake of air to get a positive pressure. All intake is filtered and the "excess" air is getting pushed out "blocking" dust from getting in. With negative pressure the air gets sucked in unfiltered in all small gaps and openings in the chassi. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2018 Only issue with that setup is that GPU isn't getting any fresh air. ^^^^ That's my post ^^^^ <-- This is me --- That's your scrollbar --> vvvv Who's there? vvvv Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
