Hello community! :)
I want to get a really good pc that can play games at a high fps!
I just want a pc that's around $10000 that I can spend. I want to play on triple 4k monitors so if you guys can get parts together that I can build, that be great :).
Note that i'm not going for a budget build.
What I need:
Processor
MotherBoard
Cooling
VideoCard
Case
Ram
PowerSupply
Sli Bridge
*If I'm missing anything let me know*
I kinda just want the best of the best parts that's at the market :)
https://linustechtips.com/topic/872550-help-me-spend-10000/
What currency?
There's probably about 12 countries, if not more that use the $.
I don't see gaming on surround 4k monitors as worth it. Just get one. You don't need to spend anywhere near $10k. Frankly, it seems trolly, and isn't a smart use of the money.
Other than that, welcome to the forum :)
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815605
if you're a troll; please remove yourself from this environment
if you're not a troll; you're throwing your money out the window for getting a less practical gaming experience than you could get for less money.
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815617
but... but...
Encourage a friendly atmosphere... Not trying to mini-mod :)
True, you could spend 1/10th of that have an ok or at tops 1/2 and get awesome experience.
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815625
Triple 4K...
Well, nothing can run that! Maybe 2 titan V's in SLI but 1) that might not fit in your budget (they are 3K a piece) and 2) they might not even support SLI.
For now, I would get an ultrawide 144Hz IPS G-sync monitor, imo the best option for gaming, for now. And actually possible to drive properly with hardware that's available!
And as people have said, go nuts on pcpp and see what you end up with, we'll adjust it if necessary :P
edit: depending where you live, contact your local pc boutique builder and see what they have to offer for such price. In germany for example it's possible to get highly overclocked systems that are custom modded so only a handful of them are made.
To give you an idea what i mean, something like this: https://www.caseking.de/der8auer-hologramm-intel-i7-8700k-5-1-ghz-2x-gtx-1080-ti-sipc-216.html
Might even be overclocked by der8auer himself, who knows :P
Or something like this (check the cooling :p) https://www.caseking.de/der8auer-aqua-exhalare-i7-7800x-gtx-1080-sipc-208.html
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815636
2 minutes ago, warstm said:
if i had that kinda money this is more or the less the build i would do it minus the fact i would do a custom loop instead but maybe start here if your looking for one
https://ca.pcpartpicker.com/list/7c6QFd
you could pretty much cut that budget to 2/3rd without losing a single frame. which kinda is my opinion as a whole when spending past 3-4000 buckaroo's on a system. at some point all you're adding is streetcred and bling.
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815642
2 minutes ago, samcool55 said:
Triple 4K...
this thing ran triple 4K and a ultrawide... https://www.pugetsystems.com/featured/Barnacules-Workstation-137
He did upgrade to dual Titan X Pascals
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815647
PCPartPicker part list: https://pcpartpicker.com/list/RjPm4C
Price breakdown by merchant: https://pcpartpicker.com/list/RjPm4C/by_merchant/
CPU: Intel - Core i9-7900X 3.3GHz 10-Core Processor  ($959.89 @ Amazon)
CPU Cooler: Fractal Design - Celsius S36 87.6 CFM Liquid CPU Cooler  ($118.89 @ SuperBiiz)
Motherboard: Asus - ROG RAMPAGE VI EXTREME EATX LGA2066 Motherboard  ($649.99 @ B&H)
Memory: G.Skill - Trident Z RGB 64GB (4 x 16GB) DDR4-3600 Memory  ($1064.99 @ Newegg)
Storage: Samsung - 960 Pro 2TB M.2-2280 Solid State Drive  ($1214.99 @ Newegg Marketplace)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($95.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 1600W 80+ Gold Certified Fully-Modular ATX Power Supply  ($359.89 @ B&H)
Monitor: Asus - PG27AQ 27.0" 3840x2160 60Hz Monitor  ($899.00 @ B&H)
Other: GTX Titan V ($2999.00)
Total: $10160.62
Generated by PCPartPicker 2017-12-12 18:09 EST-0500
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815692
35 minutes ago, Epic101 said:
Snip
If 4k Gaming is your desire, there might be a place for Ryzen. If you're going to game and ONLY game, especially if you intend to game at high refresh rates (not currently possible in 4k with the limited amount of GPU strength on the market) then you get an 8700k. There is no sense in you spending more money on X299/X399 as they perform outright worse in gaming situations than the 8700k (they are more powerful CPU's overall, but their design holds them back slightly when thrown at gaming workloads).
But for real. Having an arbitrary marker of 10k to spend and requiring us to get there feels like a troll. 8700k + SLI 1080ti + 1 of NVMe storage, 32GB RAM, and a full custom water cooling loop costs you about half that.... and that's already over the top as it is... but on the chance anyone here actually wants a top-of-the-line overkill gaming system and has the funds for it, this is what you should do: https://pcpartpicker.com/list/fnmfJV
Those parts are mostly guidelines based on current market prices... and you could save a lot of money by trimming some of the fat off that system. pair it with whatever kind of monitor you wish, likely 4k or ultrawide... but yeah... there is 0 sense in spending any more money than that on a gaming system as your performance only gets worse if you do, or you're just throwing your money away at superfluous things... and that build is pretty over-the-top as it is.
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815748
Im not being a troll is because idk maybe because i want a titan v :P
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815931
4 hours ago, dizmo said:
What currency?
using usd
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815934
Total: $10160.62
Dont include the monitors cause i have them.
I honestly would like to have most likely 2 graphics card but thats just me. What is the difference between Titan x - Titan z - Titan v
i really cant find a different.  I mean titan v already cost $3000 but titan x is legit half the price. Will there be a different performace if i had 2 titan x instead of 1 titan z.
Btw im going for a black and red setup
*if it didnt include monitors*
https://pcpartpicker.com/list/4JnTd6
also include the windows 10 home because i kinda want windows 10 :)
also i need wifi to be wireless and I'd like to have an extra storage thats like the ssd but not m.2 style.
this pc build is mostly used for gaming and making videos and streaming
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10815969
Titan Z- old; don't buy
Titan X- usable but for the price just get Xp because it's newer
Titan V- bleeding edge and only really good for deep learning or flexing on your friends with your dope new gold graphics card
Titan Xp- 2 of these and you're set for overkill
If you don't need monitors, add cooling loop, more storage, and upgrade CPU (if you want)
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10816016
Would you mind giving me a new list for the things and include the 2 titan xp to see the price. Give me like what would you have in your $10000 cause i just want to have a beast build for gaming, making videos, and streaming
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10816045
PCPartPicker part list: https://pcpartpicker.com/list/XKhPtJ
Price breakdown by merchant: https://pcpartpicker.com/list/XKhPtJ/by_merchant/
CPU: Intel - Core i9-7980XE 2.6GHz 18-Core Processor  ($1971.88 @ Newegg Marketplace)
Motherboard: Asus - ROG RAMPAGE VI APEX EATX LGA2066 Motherboard  ($429.99 @ B&H)
Storage: Western Digital - Gold 12TB 3.5" 7200RPM Internal Hard Drive  ($419.99 @ B&H)
Case: Phanteks - Enthoo Elite (Black) ATX Full Tower Case  ($924.98 @ Newegg)
Other: GTX Titan Xp ($1200.00)
Other: Loop ($1176.14)
Total: $9962.85
Generated by PCPartPicker 2017-12-12 19:50 EST-0500
Here's what I would do.
Disclaimer: I don't know basically anything about a cooling loop so I set that up in EKWB config. If you're planning on spending this much on a PC, I'd do more research and hand pick each component of the loop.
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10816062
I would much rather spend 3333 dollars 3 different years so that you can get high end performance for 3 different years
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10816075
Ok, so besides being ludicrous, this is what I'd do if I was making a build and had a massive budget.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($404.99 @ B&H)
CPU Cooler: Thermaltake - Floe Riing RGB 360 TT Premium Edition 42.3 CFM Liquid CPU Cooler  ($199.99 @ Amazon)
Motherboard: Asus - ROG MAXIMUS X HERO (WI-FI AC) ATX LGA1151 Motherboard  ($264.99 @ SuperBiiz)
Memory: Corsair - Vengeance RGB 32GB (4 x 8GB) DDR4-3466 Memory  ($449.99 @ Amazon)
Storage: Samsung - 960 EVO 1TB M.2-2280 Solid State Drive  ($449.99 @ Amazon)
Storage: Crucial - MX300 2.0TB 2.5" Solid State Drive  ($515.99 @ SuperBiiz)
Storage: Hitachi - Ultrastar He8 8TB 3.5" 7200RPM Internal Hard Drive  ($265.00 @ Amazon)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING X TRIO Video Card (2-Way SLI)  ($799.99 @ B&H)
Case: NZXT - H700i ATX Mid Tower Case  ($199.99 @ Amazon)
Power Supply: SeaSonic - PRIME Platinum 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($229.99 @ SuperBiiz)
Total: $4845.90
Generated by PCPartPicker 2017-12-12 19:59 EST-0500
  • The 1080Ti is damn near par with the Titan XP. Within 2% IIRC.
  • More than enough power for overclocking.
  • 1TB for OS/needy programs, 2TB for games, and 8TB (I'd run them in RAID for redundancy) for mass storage.
This is what I'd actually do with the money. I didn't just go pick the highest cost items from each category.
You can of course pick a different case, etc.
I also assumed it'd mostly be gaming since you didn't give us much to go on.
Here's an over the top white build for something a little different.
Motherboard: Asus - PRIME X299-DELUXE ATX LGA2066 Motherboard  ($498.32 @ B&H)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3600 Memory  ($234.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB FTW3 ELITE GAMING WHITE Video Card (2-Way SLI)  ($1048.53 @ Amazon)
Case: Corsair - Crystal 570X RGB White ATX Mid Tower Case  ($179.99 @ Corsair)
Power Supply: EVGA - SuperNOVA P2 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($279.46 @ B&H)
Total: $7415.65
2 hours ago, Ryois said:
but... but...
I'd say trolly posts go against encouraging a friendly atmosphere, wouldn't you? ;)
Titan Z - Obsolete
Titan X(P) - Newest, 2% faster than a 1080Ti at a 50% price increase
Titan V - Designed for scientific loads etc. Not for gaming, likely not for you
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10816109
ok so guys
This is what i picked out.
https://pcpartpicker.com/list/vWdn3F
Kinda need a good cpu cooler so if you can just modify it that be great
also, whats a external storage? do i need it when i got a ssd and hdd?
Also give me a good wireless wifi card cause i cant tell :P
Other then that do i need case fans, fan controller, themeral compound, or a UPS?
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10816412
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler  ($147.99 @ SuperBiiz)
Memory: G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-3866 Memory  ($599.99 @ Newegg)
Storage: Samsung - 850 EVO 4TB 2.5" Solid State Drive  ($1545.00 @ Newegg Marketplace)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB K|NGP|N GAMING Video Card (2-Way SLI)  ($999.99 @ B&H)
Case: Phanteks - Enthoo Series Primo Aluminum ATX Full Tower Case  ($259.98 @ Newegg)
Total: $9001.13
Generated by PCPartPicker 2017-12-12 21:41 EST-0500
https://linustechtips.com/topic/872550-help-me-spend-10000/#findComment-10816415
