Help Me Pick A Graphics Card
Solved by Tz000,
I have a ryzen 5 1600 oc'd @ 3.9Ghz w/ Asus RX 580 8GB this is all paired to a asus mg248q 144hz display.
In terms of gaming performance heres a bit of a list w/ fps numbers / settings EDIT: ALL @ 1080P
CSGO - 300+ FPS - Custom settings med/low
PUBG - 70-95 FPS - Custom settings low/ultra
FORZA HORIZON - 90+ FPS - Custom Settings mostly set to high.
BF1 - 90+ FPS - High settings
COD WW2 - 85+ FPS - High settings
If settings are really knocked down these numbers easily go over 100 FPS but with freesync and on most games 75+ fps its a great experience.
Hope this helps.
Cheers
