Hey guys,
I have a beginner to moderate skill in electronics and soldering,
There are loads of open source plans for building DACs, and I was wondering if anyone has built/created one before and what was the difficulty factor, + price?
I just bought a pair of Sennheiser 558s and my on board audio is just not good enough to drive these!
Thanks guys
https://linustechtips.com/topic/83956-dacs-building-a-dac/
just get a fiio e10 AFAIK those things are complicated as heck and if you decide to build one yourself it would probably be really weird
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143047
From the schematics that I've looked at, they don't look too complicated to build, but I guess they are very small and it would prove difficult unless I have a steady soldering hand, which luckily I do ;)
I'm just after an opinion from someone that has built one before and if it's worth the hassle. I have 5 or 6 electronic projects to do over the summer, so why not add another one ;)
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143066
If he specifically wants to build one, suggesting that he should buy one doesn't really help a lot does it.
That being said as long as you're pretty good with a soldering iron and know how it all works, a DAC is not necessarily the hardest thing to build. Whether or not the result will be comparable to or better than prebuilt solutions depends on what you build.
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143069
the o2 is open source, I don't know how you would build it but you can. The most benifit you will get is from an amplifier and not a dac really.
Most parts I believe are simply off the shelf from electronic/hobby shops, it's not that hard to find parts. I thought about going down the pre-built amp route, but I love creating my own gear.
Yeah, pretty much, I could just buy one, but where's the fun in that!
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143085
you can totally do it. My friend is creating his own amp, he's got the blueprints and is soon constructing. If you know your stuff, you can do it.
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143093
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143094
/me whispers what's a DAC?
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143115
Best bet is JDSLabs Cmoy.
Edit: my bad.. Thought discussion was amps. Agreed with tge the general consensus though, building a dac isn't efficient but it's a good learning experience imo. I think whether or not the work is justifiable is OP's decision.
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143129
Building an amp is relatively easy and fun. Building a DAC is less so and you might as well just buy one.
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143241
Still not really true. There are no tubes in a DAC of course, so I guess one could say building an amplifier is more fun. Preeeeeetty glooooooowing tuuuuuuuuubes. <3
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143355
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143534
i could have bought a 60% keyboard and it would have cost me half as much a building one but building it is much more fun, that is the only real reason. Same kind of thing with a DAC.
Desktop -  i5 4670k, GTX 770, Maximums VI Hero, 2X Kingston Hyper X 3k in raid zero.
Laptop - Lenovo X230 Intel 535 480GB, 16GB Gskill memory, Classic Keyboard Mod, Triple USB 3.0 Express Card.
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1143757
If you want to build a DAC for the fun of it, then build DAC,  if you want a dac for s purpose then just buy one.
I have been thinking about building one for the sake of it, but people going to start calling me halfa or gunna with the amount of half done stuff I'm gunna do lying around here.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1144082
Haha I feel your pain main, so many projects on the go, but it's mostly because I was busy as hell with university, but now that I'm on summer break, ALL THE TIME TO FINISH PROJECTS! :D
I might buy a pre-built one, but also build the same one, and see what the quality is like between the two, I just feel much more satisfaction out of building something I guess!
https://linustechtips.com/topic/83956-dacs-building-a-dac/#findComment-1145131
