I am planning on building my first NAS running in RAID 5, the primary uses of the NAS are going to be PLEX (transcoding needed), torrenting (Transmission), SAMBA, nightly back ups with Apple Time Machine, FTP server, and I would like to have the option to run a VM.
I was originally going to buy a Synology DS916+ but it seems the transcoding for 1080 might be lacking and 4k would be nonexistent.
Questions:
  • Would the CPU's on board graphics be enough for my application?
  • Am I going to need a RAID controller?
  • Do my hardware choices seem sound/compatible? Last time I built a computer was in 2008.
  • (1) 16GB DDR4 ECC RAM or 2x8? I might want to expand to 32GB later
  • What are my OS options? What is recommended?
  • Am I missing anything?
  • What brand of hard drives are  recommend? I am currently looking at WD Red 4TB.
  • Should I include a Cache SSD?
CPU: Intel - Xeon E3-1245 V5 3.5GHz Quad-Core Processor  ($281.05 @ OutletPC)
CPU Cooler: Noctua - NH-L9i 33.8 CFM CPU Cooler  ($39.15 @ Newegg)
Motherboard: ASRock - E3C236D2I Mini ITX LGA1151 Motherboard  ($236.49 @ SuperBiiz)
Memory: Kingston - ValueRAM 16GB (1 x 16GB) DDR4-2133 Memory  ($158.99 @ SuperBiiz)
Case: Lian-Li - PC-Q25B Mini ITX Tower Case  ($105.98 @ B&H)
Power Supply: EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($85.98 @ Newegg)
Case Fan: Noctua - NF-F12 PWM 55.0 CFM  120mm Fan  ($19.11 @ Newegg)
Case Fan: Noctua - NF-A14 PWM 82.5 CFM  140mm Fan  ($21.05 @ Newegg)
Total: $947.80
Generated by PCPartPicker 2017-09-01 20:56 EDT-0400
https://linustechtips.com/topic/829801-critique-first-nas-build/
Xeons do not have on board graphics. Also, perhaps Epyc/Ryzen/Threadripper? (Ryzen and Threadripper are repurposed server products)
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I was under the impression that the E3-1245 v5 was the E3-1230 with on board graphics? Am I mistaken?
You should look into used parts. You can pick up old Xeon hexa-cores and their boards for about $300 on Ebay. How many users are you targeting (endpoints)? How many disks will you need? Will it be tower or rack? Do you have a backup planned?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
All Xeons don't have on board :/
Full Specs
Helios EVO (Main):
Delta - Laptop
"thumbs up, 20 times"
Full Specs
Helios EVO (Main):
Delta - Laptop
The 1245 has onboard graphics.
welp
i'm having a brainfart today :o
Full Specs
Helios EVO (Main):
Delta - Laptop
I noticed. #BurnHeal
The 1245 does.
@tsegreto A lot of server motherboards have onboard video chipsets (so you don't need to waste money buying a 1245 over a 1231.
18 minutes ago, tsegreto said:
Questions:
Total: $947.80
You don't need any gpu power, you just need video outputs (so motherboard integrated graphics is fine).
You don't need a RAID controller if you use something like FreeNAS or Storage spaces.
The PSU is overkill as are the fans (most fans running at 5v are pretty quiet.
The motherboard is expensive and I would personally aim for something with Supermicro's IPMI or something comparable (it allows you to remotely control the NAS over ethernet -- so you don't need anything connected to the server other than an ethernet cable.
1x16 is fine.
FreeNAS, Windows Server, Windows 7/8/10, whatever Linux Distro you prefer.
This Asus board has integrated graphics built into the motherboard, so you can get a 1230v5 and save some money, and it also has a dedicated manage ethernet port (so you don't need to go near the server to access it/turn it on/turn it off/enter the bios/etc...).
https://www.newegg.com/Product/Product.aspx?Item=N82E16813132820
And a mini-SAS to 4x sata if you need more than two sata ports: https://www.amazon.com/Cable-Matters-Internal-Mini-SAS-Breakout/dp/B012BPLYJC
PSU Tier List | CoC
Gaming Build | FreeNAS Server
7 minutes ago, tsegreto said:
-snip-
Yeah, try to shop for used parts as mentioned above. But try to keep the CPU within reason...transcoding isn't that hard on the CPU.
As someone with hardware RAID, I wouldn't recommend it for a small NAS. It's way too expensive (for a good one).
You should try software RAID using FreeNAS / Unraid and use a HBA. Storage Spaces in Windows works alright as well.
The OS pretty much depends on what you prefer. I run Windows Server myself, but that's because I'm used to it (and I have a hardware RAID card)
would be way better just forget about the SSDs
CPU: Intel - Celeron G3900 2.8GHz Dual-Core Processor  ($38.99 @ OutletPC)
Motherboard: ASRock - E3V5 WS ATX LGA1151 Motherboard  ($100.98 @ Newegg)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($144.99 @ B&H)
Storage: Seagate - Constellation ES 3TB 3.5" 7200RPM Internal Hard Drive  ($99.99 @ Amazon)
Power Supply: SeaSonic - G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($68.99 @ SuperBiiz)
Other: NORCO RPC-2008  ($190.00)
Other: supermicro raid card ($140.00)
Total: $1628.86
Generated by PCPartPicker 2017-09-01 21:12 EDT-0400
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
3 minutes ago, djdwosk97 said:
The 1245 does.
1x16 is fine.
Thank you!
Space of the NAS is a concern though so I am looking at Mini-ITX motherboards. Do you still think the 1231 is a better option than the 1245? What power supply would you recommend - I picked that one because it is modular and I read that the space inside my case is pretty tight.
You can find some old Dell or Lenovo servers (tower or rack) on Ebay for about $300 like the Dell R710 rackmount.
3 minutes ago, tsegreto said:
Thank you!
The motherboard I linked is also mITX, but it also has onboard motherboard graphics and remote management. So, I'd definitely save the $50~ and get a 1230 (I would also strongly consider an R5 1600/R7 1700).
The CX450m is $18 after a $20 rebate with code: EMCRKRB47
https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139146&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
PSU Tier List | CoC
Total: $1628.86
Why not fucking ryzen?
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
the cpu is cheap but it works fine, I also wanted ECC and a good mobo
ECC, FreeNAS guaranteed compatibility, hardware remote management, onboard motherboard graphics.
Most Ryzen boards don't fully support ECC, unless that has changed? Also, last I checked, FreeNAS still wasn't certified on Ryzen (not that OP has decided what OS he's using, but I personally wouldn't want Ryzen until it was guaranteed with FreeNAS and with full ECC support -- as well as some hardware remote management and on-motherboard graphics).
PSU Tier List | CoC
ECC = Good to have on servers that run 24/7/365.25.
Sure... Does a celeron have ecc memory support though?
yeah
Usually. Pentiums and some i3's have ECC support as well. i5 and i7's do not. That's why Pentiums sell much better in the server market for (for those who can't afford the end-chip for their desktop) upgrade path to an i5 or i7 vs getting an i3 from the get-go.
15 minutes ago, GDRRiley said:
yeah
2 minutes ago, ARikozuM said:
Usually. Pentiums and some i3's have ECC support as well. i5 and i7's do not. That's why Pentiums sell much better in the server market for upgrade path to an i5 or i7 vs getting an i3 from the get-go.
good to know
2 minutes ago, Jrock said:
good to know
Hopefully the Coffee Lake i3 quad-core retains ECC support. Should make for a beastly server.
Total: $1628.86
Good but if OP wants any chance at running a nice VM dual core isn't enough
"I'm not really that old, I'm just 18 + shipping" -Unknown
Please tell me why you aren't on dark theme already.
Herro my dark theme brothers.
Laptop: MacBook Pro Mid-2012 Non-Retinai7-3720QM, 8GB DDR3L-1600, 250GB SSD, macOS 10.13
Phone: iPhone 7 Plus that is patiently waiting to be jailbroken.
