I am looking at building my first desktop PC and have done some research and picked out these parts (look at list). I plan on using it for gaming, video editing, streaming and just general use. I sit basically right on budget too, so not looking to upgrade many parts without downgrade others. Also i want to be able to play AAA games.
https://au.pcpartpicker.com/list/pW3jr7 (Part List)
2017-08-05 13_50_58-System Build - Ryzen 7 1700 3.0GHz 8-Core, GeForce GTX 1080 8GB AMP! E... - PCPa.png
https://linustechtips.com/topic/817636-first-pc-build/
Improved some bits and it's cheaper overall:
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($399.00 @ Shopping Express)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($143.00 @ IJK)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($195.00 @ Umart)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($128.00 @ Shopping Express)
Storage: Toshiba - 3TB 3.5" 7200RPM Internal Hard Drive  ($121.00 @ IJK)
Video Card: Zotac - GeForce GTX 1080 8GB AMP! Edition Video Card  ($799.00 @ Scorptec)
Case: NZXT - S340 Elite (Black) ATX Mid Tower Case  ($149.00 @ PLE Computers)
Power Supply: Fractal Design - Edison M 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($109.00 @ Mwave Australia)
Total: $2043.00
Generated by PCPartPicker 2017-08-05 14:09 AEST+1000
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252407
Total: $2043.00
Is 550W enough, some friends recommended more.
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252420
Havent got time to correct it myself, but I'd give it a 6/10.
1. Ryzen loves fast RAM, so get 3000MHz ones (3200 ones are expensive for that extra speed)
2. Either get a cheap ~120GB SATA SSD as boot drive or 240GB+ Samsung drive as a fast storage drive. Intel SSDs suck anyway. 3. A 550W unit is already enough for your build. Unless it is the cheapest PSU that has good quality and on or above this power rating, get another one.
Desktop benching:
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252439
You're talking maybe 350W in a worst-case scenario. Your friends are overestimating the power consumption of the rig.
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252443
2 minutes ago, mattrhook said:
What is nvme?
A faster data transfer protocol than SATA.
Desktop benching:
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252449
Id like 3tb and also the 250gb ssd, preferably m.2 because of the speed
Not really worth it
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252461
So maybe go for 120gb m.2 and keep the speed?
It's not worth it though
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252470
Just now, mattrhook said:
Why? Because of the price?
You will get .5 second faster boot time and you give up $25-50.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/817636-first-pc-build/#findComment-10252475
