I want a tempered glass case with no fans, and tempered glass all the way around (all,sides possible). Budget is $150-$250. Must be ATX and should be capable of holding at least a 240mm rad (preferably 360mm)
CPU: Ryzen 7 1800X
CPU Cooler: H100i V2
RAM: Trident Z RGB 16GB 3000MHz Cl 14
Motherboard: ASUS RIG Crosshair VI Hero AM4 ATX motherboard
GPU: 980Ti
PSU: Rm1000x
Storage: Samsung PM961 512 GB m.2 Nvme sad
Storage: 7500 RPM 2 TB Seagate Barracuda Hard drive
Case: 570X RGB (White)
OS: Windows 10 Pro
https://linustechtips.com/topic/808517-best-tempered-glass-case/
Thermaltake Core X5
http://www.thermaltake.com/products-model.aspx?id=C_00003042
It does support 6x 360mm rads ... should be enoguh xD
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://www.pccasegear.com/products/37220?gclid=Cj0KCQjwnazLBRDxARIsAECdauuwJXqy3cxiGZAgyjdtFfaReoxqiiax8oNCjrQEJR2ydc80Gn4ylggaApJNEALw_wcB&gclsrc=aw.ds and a bonus its rgb
There's a whole tonne, I guess the Corsairs spring to mind
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
7 hours ago, Damascus said:
Get a Corsair x570 and sell the fans
This is the only one I know of that has TG all around. There's a few that do 2 or 3 of the panels but many dont do the top panel from what I've seen.
why would you want it to be all tempered glass anyways when the back and top don't look attractive at all with all the cabling and stuff...
OP i'll say this, i built a PC for a friend in a corsair 460X which is tempered front and one side and it was an aweful case to work in, no room in the back, plastic 2 piece PSU shroud is also a piece of pure shit...looks pretty good though once finish but building in was a pain...i personally bought a phanteks P400S tempered glass for my machine and i love everything about it, very nice case.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Never said it was a good case, just noted that its the only case that has TG all the way around ;)
X570 fixes those issues by having more space to work with btw.
Want to custom loop?  Ask me more if you are curious
