What is the difference between gaming motherboards and normal ones?
Solved by Mira Yurizaki,
19 minutes ago, Reem1kTechTips said:Would there be a performance difference if i scrapped a compatible motherboard from an older pc?
No.
Motherboards have little, if any, impact on performance. A motherboard is just a communication back plane. There are some features that allow for things like better overclocking, but that still depends on if the CPU is up to snuff. Plus gaming motherboards may be worse for cooling purposes. Those heat sinks covering the chipset and VRMs aren't exactly the best designed ones.
