1 minute ago, garren078 said:
I honestly don't have a budget, and I'm looking for a mid to a full tower either one would work.
colour? HDD/DD/optical drive mount support? water cooling support? windowed panels/Tempered glass? brand? desired price (i know you said no budget, but that doesn't mean you would be equally okay with spending $100 vs $500)? like @Max_Settings said, there are literally hundreds of choices if you don't help us narrow things down.
https://linustechtips.com/topic/800956-case-with-good-airflow/#findComment-10073036
Practically any decent case with a few fans can do the job perfectly fine (since you say you don't really have a budget or preferred look of tower), just as long as your cable management is alright but it still doesn't make much of a difference anyway.
Also why was this posted in the general discussion? Should have been posted in the 'Cases and Power supplies' section of the forum found here:
https://linustechtips.com/main/forum/21-cases-and-power-supplies/
Take him away boys xD @Godlygamer23 @MEC-777
IT Manager working in the Education sector.
https://linustechtips.com/topic/800956-case-with-good-airflow/#findComment-10073038
1 hour ago, Brennan_Price said:
.Also why was this posted in the general discussion? Should have been posted in the 'Cases and Power supplies' section of the forum found here:
Thread moved.
https://linustechtips.com/topic/800956-case-with-good-airflow/#findComment-10073439
Most mid to high-end cases these days have more than enough fan mounts in the appropriate locations (with a few exceptions). Just watch some reviews to get an idea (or just look at them).
What's arguably more important is to make sure you have enough fans and that they are all mounted and moving the air in the same uniform direction. Typically intake through the front and bottom, and exhaust out through the rear and top. You'll also typically want slightly more intake flow vs exhaust for a slight positive pressure inside the case. This can be achieved by optimising the fan speeds or simply running more intake fans than exhaust fans.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/800956-case-with-good-airflow/#findComment-10087527
Looking to rehouse my i7-3770k build, in preparation to update the CPU + Mobo sometime in the next year.
Looking at something simple like the Define R5 at the moment. Sound dampening isn't necessary, but willing to cash out a bit extra for it.
Something future-proof is nice. Doesn't seem like dropping 800+ dollars on a i7-7700k, z270 chipset and new DDR4 is justifiable with the i7-3770k still pulling benchmark figures only 20-30% lower for an upgrade today.
What are simple flagship cases that are the "go-to" for builds these days? It's honestly been almost 6 years since I last did a build, I'm extremely out of the loop in new components. I honestly was about to walk into a store and ask for a Define R4, didn't even know until earlier today the R5 superseded it... 2 years ago.
The Define R5 came out in 2015, I'm concerned it might be a bit dated. Are there other options to look into? I'm fine with just a few names, then I can go research for myself.
Looking for nice and simple cases to house air cooled components no stringent requirements at the moment.
This is what my current build to be ported over is currently using, in regards to tower compatibility needed:
-1x PCI-E slot
-1 Large CPU Air Cooling tower (Noctua NHD14)
-2x SSD bays, 2.5'
-1x HDD bay, 3.5'
-Non-modular PSU, tons of cables everywhere, good cable management options MANDATORY!
-A side-exhaust GTX 680 that exhausts heat up towards the Main-Side panel http://www.tomshardware.com/news/gigabyte-gtx-680-windforce-oc-gpu,15955.html
Optionally, I still have a 5.25' Optical drive which i've refrained from tossing into the bin, but if the new case has room I'll rehouse it too.
TL;DR,
Normal, basic case, must have decent width to house tall air cooler.
Sound dampening is a bonus
Side-Panel window is a bonus
Side-Panel Case-Fan mount is a bonus
5.25' Bay is a bonus.
Mid-Tower preferred, bigger is fine.
Willing to spend about $200, $150 range preferable.
Also: what is the go-to pressure-optimized 140mm/120mm case-fan these days? Might need a couple of those puppies too. I really like replacing most default case fans with silent, high performing Noctua fans.
Current Rig:
CPU i5 11600k @4.7ghtz Cooler Noctua NHD15 | RAM 32gb @3200mhz Kingston HyperX Fury | Mobo Gigabyte z590 Aorus Elite AX | GPU Gigabyte Windforce GTX1080  | PSU Corsair RM750I | Tower Fractal Define C | Peripherals Corsair K70 Cherry MX Red Keyboard, Logitech G502 Hero Mouse, Sennheiser 6xx Headphones, Beyerdynamics DT990-250 Headphones, Sennheiser Momentum 2 True Wireless Earbuds, Blue Yeti Mic, Rhode PSA boom arm, Objective2 SDAC/ODAC
https://linustechtips.com/topic/800956-case-with-good-airflow/#findComment-10087648
-snip-
The R5 was updated with the Define S
Other Go-To's are the Phanteks P400 and NZXT S340 (both have tempered glass options, you can see the S340 in my blue build)
https://linustechtips.com/topic/800956-case-with-good-airflow/#findComment-10087685
