Case with an optical drive bay or nah?
Solved by Oshino Shinobu,
2 minutes ago, RamboPenguin said:I bought the copy of windows on a disc, and I don't think I have a flash drive that's big enough to transfer it over.
You bought the license, the actual files are free and can be downloaded from Microsoft (or you can rip the ISO from the disc and burn it to a USB drive). You only need an 8GB USB drive. If you don't have one, you can buy one for $10 or so. I wouldn't buy a case just for an optical drive to install Windows once then sit there doing nothing, especially when there's easy alternatives to using a disk
