Done with my build! (for now)
reniat
This was my first venture into custom water cooling. I do plan to add the gpu to the loop (as right now it's pretty overkill for the just the cpu), as well as EVENTUALLY switching to hardline, but this was enough effort that I just kinda want to play some games on it for a while lol. Plus, I have to re-delid my processor, so I'm not really going to make the switch to hardline until I know I don't have to crack that back open....
http://imgur.com/a/ZmKo4
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
nice work, looks great
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
Nice loop, it looks great.
One question:
Why?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
3 minutes ago, RadiatingLight said:
Why?
I didn't do a very good job initially. My temperatures are awful. I think i put too thin of a layer of coolaboratory ultra under the IHS. I have the exact same performance with this MASSIVELY overkill loop as I did with my tiny 240mm H105 cooler, which to me indicates an issue with heat transfer.
Gaming build:
Server build:
CPU: Ryzen R7 1700x
PSU: Corsair CX550M
Case: HAF 932 adv
Just joined the forum? Read this:
A Quick Guide To Get Started
Need Help Doing Something? Read this:
Guides & Tutorials Catalog
Need a New SSD? Read this:
Droidbot's SATA3 SSD Tier List
Need a New PSU? Read this:
PSU Tier List
In the mood for some memes? Look at these:
Linus Memes
Want to know my PC Specs and Peripherals?
CPU - Intel Xeon E5 2609 v3     Motherboard - ASRock X99 Extreme3      RAM - 16gb HyperX Fury DDR4      GPU - EVGA Nvidia GeForce GTX 770 SC
Case - Inwin 103       Storage - HyperX Savage 240gb SSD      PSU - 550W Enermax NAXN      Display(s) - 2x Lenovo L27i-28, Dell 24"      Cooling - Corsair H100i Platinum     Keyboard - Corsair K95 Platinum MX Speed      Mouse - Logitech G900      Sound - Audio Technica ATH-M50x     Operating System - Windows 10 Pro
Join the LTT F@H Team!
You can help scientists studying Alzheimer's, Huntington's, and many cancers by simply running a piece of software on your computer.
Start now: Folding@Home Install Guide and Links
