GTX 1050 Ti+ Monitor or GTX 1060 6gb
tyler1
I have an HP 1740 monitor ( 1280x1024 ) and I'm planning to get a new PC for gaming. I have 2 choices :
  - i5 2400 / 8gb RAM / GTX 1050 Ti / 500Gb HDD / 300W Gold PSU + BenQ GL2250HM 1080p monitor
  - Xeon E5640 / 8gb RAM / GTX 1060 6Gb / 500Gb HDD
Which one do you think I should go for? Thanks in advance.
Save up a bit of money to get a better build overall + a monitor
RX 470/570 with a Freesync monitor :D
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
@PatrickK These are the only options since building my own in my country ends up being out of my budget.
@PCGuy_5960 I can't put those graphics cards on the first prebuild PC since it only has 300W PSU, plus they're more expensive than the GTX 1050 Ti so I can't afford a monitor in this case.
Well yeah, thats why i said why not save up some more and go for a better build. Idk how badly you need a new build right now though, but if possible i would personally save up a few more months, and go for a better build in general
Do you have the Xeon system with you?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Save more money for a newer build. i5-2400 struggles to keep up with modern games and who knows how long these used (like, 24/7) Xeons can last??
What is your actual budget anyway?
Desktop benching:
