How much cable sleeving will I need?
I am planning on getting an evga nex supernova 650 watt power supply and I was planning on sleeving the cables myself. How much sleeving would I need, or how much sleeving have you guys used?
Are you sure you want to do that?
Are you aware of how many days that will take and how much worse it will look than professionally sleeved cables?
When I did my sleeving, I drove the Opera to the Cablemod.com store and purchased what I needed to sleeve.
Which is to say, I didn't sleeve anything myself.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
You will need to calculate it out on the length and number of wires per connector and add them up to get an approx value from there adding another 15% is a good margin. As said you will need to take a lot of time and purchase tools to do the sleeving especially if you are making new cables, that cost alone can be as much as a sleeved kit.
-Moved to Modding Section-
Just do the Cablemod method, AKA spend money on their cables. Much easier and it doesn't take literal weeks.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
@CrunchyO123 as @STRMfrmXMN mentioned, let us make things easy, and headache free for you. :)
https://store.cablemod.com/configurator/
We have your PSU listed on our configurator page, if you need any help figuring out what cables you need to purchase, shoot an email to Support@CableMod.com and we will gladly help with whatever you need.
