Monitor stands or mounts
aprofile
Hi,
Considering getting a stand or mount for my monitor (see pics of setup attached) because I currently use a wireless keyboard/mouse but am going to upgrade the keyboard to a wired one. Want to make sure that I have enough room on my desk so it would be good if I could push my keyboard forward to make room for books etc. for me to work on. Any recommendations as to go for a stand or mount? Also any recommendations for specific models would be great (I live in the UK).
Thanks,
Dan191927.7e5d98d9c89dac285b372872a78f9413_1600.jpg.04e2d24ac0e04fd227c37bab79420b33.jpg
2 minutes ago, aprofile said:
Hi,
Thanks,
Dan
One of my favorite ones I've seen is the aluminium base from silverstone, a little pricey but really nice and simple. In the meantime textbooks are always a good option :P
https://www.amazon.co.uk/SilverStone-SST-MR01S-Aluminium-Monitor-Computer/dp/B00I6CVPZ8/ref=sr_1_2?ie=UTF8&qid=1496006360&sr=8-2
It will be cheaper for a stand and it has storage space (depends on the brand) arm it could be finicky ( still offers storage space but at a cost of visibility)
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Proabably a little expensive for me. More looking at the £20-£40 range but leaning a bit towards the lower end
1 minute ago, manikyath said:
that display looks cheaper than the monitor stands we have at work :P
It's LG 22 or 24 inch display and it would be about 100-200£
Yeah. Cost me £70 for a 1080p 60hz monitor so its not exactly great quality
There are lots of options out there, just take a look around. This looks pretty nice and fitting with the bamboo design of the desk:
https://www.amazon.co.uk/Universal-Desktop-Computer-Heighten-Notebook/dp/B013BQJIZM/ref=sr_1_25?s=computers&ie=UTF8&qid=1496006591&sr=1-25
https://www.amazon.co.uk/AmazonBasics-DHMSA-Adjustable-Monitor-Stand/dp/B00X4SCCFG/ref=sr_1_4?s=computers&ie=UTF8&qid=1496006619&sr=1-4&keywords=monitor+stand
Amazon basics FTW.Amazon Students get 15 percent off
My life
A bunch of old books.
Else I would just say "Get a new monitor with an adjustable stand"
Thanks. Guessing you recommend a stand. Will have a look at around but that one looks pretty nice.
Would prefer it to look nice and store stuff under it if I can so not gonna use some books. Don't feel like buying a new monitor either.
I second these
W-L has a good recommendation
@aprofile
If you want a more budget option, my dad uses the AmazonBasics stand and it works perfectly
https://www.amazon.com/AmazonBasics-Metal-Monitor-Stand-Black/dp/B017DOS5C0/ref=sr_1_4?ie=UTF8&qid=1496008201&sr=8-4&keywords=monitor+stand
@aprofile
Thanks. Looks pretty nice and it is very affordable so seems like a good option.
15 hours ago, antoipod said:
Yeah. I saw that too. Seems pretty good for the price so I am definitely considering it unless I see something else insanely well priced. Between this, the basics one and the bamboo one at the minute so will have a look at the reviews and differences and decide. Thanks for the help everyone.
19 hours ago, SpaceGhostC2C said:
Was considering the duronic one but not sure how it would work with a bevelled edge (see pic). I was considering slipping a small peice of wood underneath for it to clamp to but not sure.IMG_20170530_115611259_HDR.thumb.jpg.cba3e9ce91918aad0e6b2ff8ed617108.jpg
Happy I could help
