Since my GTX 1050 TI SSC died, EVGA is letting me pick one out for free and I wanted to know the difference between the various GTX 1050ti cards.
GTX 1050ti (Single fan) (normal Ti?)
GTX 1050ti FTW ACX 3.0 (What does the FTW mean in terms of specs...?)
GTX 1050ti SC (Single Fan) (Obviously 'superclocked')
GTX 1050ti SSC ACX 3.0 (super superclocked?)
I know ACX 3.0 is their dumb cooling system...
Basically out of all four, which should I get? The FTW version has a larger PCB... I was gonna get the SSC version just because it is short enough to put my 650's cooler on...
Alternately I could get a refund and buy another GTX 950 FTW and SLI it with the one I already have...I've heard add 70%...
https://linustechtips.com/topic/785628-differences-between-evgas-nonsense/
FTW>SSC>SC>Normal
The better the card the better the pcb as well as the higher the out of the box clock speeds. The SC and Normal probably have the same pcb though.
I would choose FTW, it's definitely the best one.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
1 minute ago, DocSwag said:
FTW>SSC>SC>Normal
So FTW is better than SSC....Huh...So the GTX 950 FTW is better than the 950ti SSC?
Edit: The FTW is LESS expensive than the SSC...
There was never a '950Ti'
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
SC one usually has worse power delivery and has a pretty much locked voltage usually. I'd say go for the FTW but the SSC versions are also okay since they are like the SC versions but clocked higher though idont know what kind ofp ower delivery they have
Just now, Tiwaz said:
what about the 420 ti?
That didn't have a 'Ti' model either.
زندگی از چراغ
Just now, huilun02 said:
Don't bother with SLI
You can't SLI 1050/1050Ti anyway...
زندگی از چراغ
There was the 4GB version though, so there's that. If I get another 950 FTW I can SLI it with the one I have...will that be better than the 1050 FTW?
There's a slight difference between the clock speeds of the SSC and the FTW versions. Not much to make a huge difference. The FTW is back ordered, so I guess I'll get SSC...
He meant for 950 FTW, since it supports SLI
SLI is not worth it on entry level gaming cards.
زندگی از چراغ
If you play games that work well with sli, getting another 950 would be a decent option. Otherwise, 1050 ti.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
its about overclocking capabilities not stock clock, if your card is 20mhz lower then just add that to the offset clock usually you dont need more voltage for those lower frequencies
I had my old 1050ti SSC at 2.25GHz and I bust a capacitor...twice...EVGA is letting me keep the old card, I just don't have a soldering iron small enough to fix it AGAIN.
With DifferentSLIAuto you can SLI two cards without a bridge.
I play Fallout 4, Skyrim, Dolphin Emulator, PCSX2, Oblivion, NFS Carbon...I can write a list of the 40+ games I play...
we're talking about a 950 here, having an SLI set up with two 950's would make absolutely no sense.
زندگی از چراغ
The FTW uses a custom PCB and should overclock better. The SSC is just a higher clocked SC for people who don't want to manually overclock, and the SC is just a higher clocked normal card for people who don't want to manually overclock.
USEFUL LINKS:
PSU Tier List F@H stats
One of the reasons I liked the SSC was because it was the short PCB and I could fit my GTX 650's cooler on it. I also put a custom LED fan on it...lemme see if I can find a pic.
If I get the FTW, I'm putting the 950's ACX 2.0 cooler on it because it looks better...if it fits...
Then why did EVGA even put an SLI connector on it? I can get one used for $100...
I don't care if you can get a used for for a $100 it still makes no sense to do on such a low-end card, you might as well look at used 960's or look at new 1060 6GB's.
زندگی از چراغ
Because it was still supported. However, few people SLI lower end cards and it's not really worth it. You could spend the same amount of money on the two cards as you would a single card and basically get the same performance.
Just now, Blebekblebek said:
I am actually hope you to get additional 950 and SLI it
Since you so sure about getting 70% performance.
Well, I mean sure, if you even can get there 70% MORE PERFORMANCE with 140% more headache.
70% is just what I've heard...I even said that in the OP...
If I spend $100 more I can get a 1060. But I need that $100 for food or it's ramen noodles for the next month and a half.
Spend the $100 more on the 1060, you won't regret it.
زندگی از چراغ
