Lowest GPU for 1080p FPS 60 less
Solved by Darkseth,
If you don't have enough fps, you reduce Quality settings. NOT Resolution.
Resolution is the thing you reduce, when you already hit LOW settings.
720p on a 1080p Monitor in Ultra will look much worse, than 1080p in Medium.
You pretty much... Always run the native resolution, period. Except higher with DSR / VSR.
Featured Topics
Manv2000 ·
Posted in Troubleshooting0 -
7
QMalcolm ·
Posted in General Discussion1 -
FrozenHydrangea ·
LingoInv ·
Posted in Graphics Cards1 -
12
1
EzioWar ·
Posted in CPUs, Motherboards, and Memory1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
