GTX 1070 founders edition or zotac amp extreme
Solved by Princess Luna,
3 minutes ago, HDshiny said:is it potable to over clock the founders edition and then watercool it so make better and quieter than the third party cards ?
Yes but if you're going to go through the hassle of watercooling you should get the GTX 1080 instead since the process is not easy and only makes sense on a card that can take more advtange from the overclocking, you could say that water cooling a 1070 is pointless since it doesn't suffer from thermals to begin with nor it'll help noise at all when comparing to the already dead silent Strix.
