I7 6800K OC problems
1 hour ago, GingerGoPro said:
Thank you very much for the help :D @PCGuy_5960 Thank you for the awesome help too ^^
I will come back and inform you my sucess/failiure after some testing :D
You're welcome man.  Also, here is a great guide from Raja at Asus.  Read it a few times and you'll go places.
http://edgeup.asus.com/2016/06/17/broadwell-e-overclocking-guide/
@done12many2
I just ran IntelBurn TestV2 at 4.3Ghz annd 1.325V 20 loops on standard. After it was done it said my system is stable. Is it a reliebel stability check?
Currently running prime95 to check temps and stability.
@done12many2
I personally use RealBench (stress test portion), but you can use whatever you are comfortable with.
