DaVinci Resolve Not Using 100% GPU
Go to solution Solved by Enderman,
6 minutes ago, Miguel552 said:
So what's the point of getting all those high end rigs if they can't use the GPU to its max?
For gaming? Who's high end rigs are you talking about?
People who do video rendering spend thousands more on their CPUs than their GPUs.
It still helps to have a GPU though, 30% on a titan XP is still way more power than 30% on a 1050ti.
There are however many other programs that do use near 100% GPU during rendering, such as graphic design and that kind of stuff.
1 minute ago, Miguel552 said:
Hey everyone, I just tried DaVinci Resolve for the first time and I noticed that my CPU is 100% but my GPU hovers around 30%, shouldn't it use 100% GPU too to speed things up? Any advice would be awesome. Thank you all for your response.
You're experiencing a CPU bottleneck. Your CPU is too weak for your GPU, it can't keep up with it. If CPU usage was not 100 %, GPU load would me much higher
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
adding to that i would like to know your cpu and gpu
His profile says i3 6100 and Gtx 970.
That seems for me to be a bottleneck system....
And video editing is known to use CPU a lot :)
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
Actually, sorry about that, I'm using my laptop, Core i7 - 4710HQ with a GTX 970M 3GB.
Most rendering programs that are GPU accelerated do not use anywhere near 100% GPU, depending on the codec.
Thought this was about gaming and FPS, my bad
HWBOT
Davinci resolve is a video editing program ;)
Ahh okay. Well, I guess I'll just have to wait the time then, until I can buy a real editing rig. Thank you for your input.
  • 1 year later...
  • 1 year later...
I had a similar setup, Quadcore I7 Latop Nvidia 1050 3gb graphics davinci, I configured the render to force CUDA and my GPU and it tripled the GPU usage and better than halved my video rendering time.  CPU is still maxed out, but it's definitely faster to render.
i can tell you that i've been trouble shooting davinci for a while now and mine runs the same way i've never seen it run very high on the gpu
there are some work arounds i'm trying to help make it faster i been watching videos bc i still dont know my way around the program its going to take awhile
try watching this and take this step i'm just about to try it myself it see if it helps
not sure the problem your having but mine plays fine .. just makes it really hard to work with when start throwing in edits bc it becomes very slow playback just goes way down
yea if i had any idea that my i7-8700 wasn't going to be enough i would have taken a different approach lol
trying some workarounds tho we'll see what happens
