samsung magician failed to create bootable usb device for secure erase
Kankitst
hello.
I have a problem about create bootable usb for secure erase with Samsung magician on ssd850evo that I buy about 3 days ago.
it said "failed to create bootable usb device for secure erase" . I already try with many usb drive and reinstall windows on both mbr and gpt. or set IDE AHCI.
Is it because bad ssd or software problem here.
if it because bad ssd. I wil return it to store.
thank you very much.
3 minutes ago, Electronics Wizardy said:
what are you trying to do?
Same exact question, the question is phrased a bit peculiarly.
I want to create a bootable device for when time I need to use come.
Just want to kept it like a tool.
if i get some trouble in future.
19 minutes ago, Kankitst said:
hello.
Have you tried just making a Win 10 bootable (download it from their website) USB drive and also don't worry about the samsung software if you want to erase a drive properly just use partition manager on a different PC and delete everything and nothing will be left. (if that is what you want to do)
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
An 850EVO as a bootable backup drive? Damn, how much did that thing cost? Either way, try other tools, like CMD, to make it bootable. That is the standard way to do it.
LoL
I mean.
I want to create a usb drive for bootable device for secure erase 850evo.
I'm not good with english.
I'm sorry. If I cant answer properly.
2 minutes ago, Kankitst said:
LoL
I mean.
No prob man, we cool with English learners. Either way, like stated, CMD bootable process is like, the best way to do it. I'll send the link right here:
BTW this works for every windows version, don't worry about the title.
Yeah.
But the problem is not create bootable usb device.
It was create secure erase device.
When I go to samsung magician secure erase page and press start button to create secure erase boot device.
it said fail to create.
I want to check is anyone get the same result.
That i can confirm is it was software issue or not.
Just now, Kankitst said:
Yeah.
Naw, I've never used that tool for anything boot related. Sorry.
It ok.
Thank you very much for help.
  • 6 months later...
I know this thread is quite old, but I was just pulling my hair out over the same problem and ended up here thanks to Google. Turns out Samsung Magician only likes unformatted USB drives. So what you need to do is open CMD or Powershell with administrator rights and run Diskpart, after you issue the command LIST DISK to see what drive is your USB drive. If you found your USB drive type: SELECT DISK x (replace x with drive number) and then type CLEAN.
Restart Samung Magician and the bootable USB drive should be created correctly now.
My rigs:
NEW Ryzinator build:
CPU: AMD - Ryzen 9 3950X 8-Core Processor
Motherboard: Asus - PRIME X370-PRO ATX AM4
RAM: Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2666 @ DDR4-3066
Storage: (3x) Samsung - 850 EVO-Series 500GB 2.5", Samsung - 960 EVO 250GB M.2-2280
PSU: Seasonic Prime TX-750
OS: Microsoft - Windows 10 Pro 64-bit
Additional fan: Noctua - NF-A14 PWM 82.5 CFM 140mm Fan
Case: Fractal Design - Define R5 (Black) ATX Mid Tower Case
GPU: ASUS Radeon RX 580 Dual OC 4GB
Display: MSI 27L Optix MAG272QP @ 165Hz
OLD Build (SOLD):
CPU: AMD FX-6100 Motherboard: ASRock 960GM/U3S3 FX (VRM overheating, don't buy) RAM: 8GB Kingston ValueRAM GPU: Onboard ATI Radeon 3000 Graphics Case: Corsair Obsidian 500D Storage: Hitachi HDS721010CLA332 1TB, 119GB SAMSUNG MMCRE28G5MXP-0VBH1 (SSD), 465GB Western Digital WDC WD5000AZRX-00L4HB0 (SATA)  PSU: Be quiet! - Straight Power 10 400 Watt Cooling: Cooler Master Hyper 212 EVO OS: Windows 10 Pro x64
Retro gaming build:
CPU: Intel Pentium 3 Coppermine @ 800MHz Motherboard: Asus P2B i440BX BIOS 1012 FSB: 133 MHz RAM: 1x 128MB Hynix PC133 SDR SDRAM GPU: ATi Radeon 9200 256MB AGP Case: Full Tower case (unbranded) Storage: CompactFlash card to IDE converter (16GB card) Sound Card: Aztech 2320 ISA Cooling: Stock heatsink fan OS: Windows 98 Second Edition
  • 7 months later...
  • 5 years later...
While this thread is now very old, I wanted to thank you as this is still the resolution to getting that damn bootable drive to work. And I tried everything else.
Thanks again from the future!
  • 2 months later...
Just wanted to add that the Samsung Magician software seems to be a bit selective about USB flash drive conpatibility. I tried several Sandisk and PNY flash drives to no avail.
A reddit post said that they kept trying and found a USB drve that worked. I kept trying and had an ancient Jetflash 2gb drive that did work. The Jetflash drive had data on it and did not need the CLEAN command.
The secure erase feature seems to work at the controller level and takes about 5 seconds. It works great!
  • 2 months later...
I must agree, that it is VERY difficult to find a USB drive that works, I've gone through a bunch but Samsung keeps spitting out errors that it failed to create a bootable USB device. May end up reinstalling windows on it and calling it a day.
