Hey everyone, I don't know java. I would learn it but I am learning another language and I would rather not mix and match, I learned from that mistake in highschool. Anyways I have a blog and I would like to add a script that would redirect users to a random page each time they visit. I found this online:
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
   "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title></title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<script type="text/javascript">
(function(n){
 var pages = ['page1.htm', 'page2.htm', 'page3.htm'];
 n = n < 3? 0 : n < 8? 1 : 2;
 window.location.replace(pages[n]);
})(Math.floor(Math.random() * 10));
</script>
</head>
<body>
</body>
</html>
And it works but I get redirected to different pages every second. I was wondering if any of you could help me fix this. Thanks in advance! :D
https://linustechtips.com/topic/701195-need-a-delay-java/
Firstly, not sure would would do this I would hate it as a user. Secondly have a look here http://www.w3schools.com/js/js_timing.asp
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8965387
The page wouldn't redirect the user when I used the code there.
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8965406
Plus both codes don't offer what I am looking for. I am looking for a delay after a redirection not before the redirection. Either I can do this or maybe someone could point out the flaw in the code above that is making this wierd loop. I don't do java and it would take some time for me to get it without learning the language.
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8965417
set time out loads the function the waits for the time then starts, your first redirect will of course wait 3 seconds then change, which will trigger and wait 3 seconds then change.
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8965693
4 hours ago, WhatComesAround said:
I don't know java.
The code that you have listed is not Java...
That is an absolutely ridiculous excuse.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8965926
<html>
<head>
<title></title>
(function(n){
</script>
</head>
<body>
</body>
</html>
Assuming you meant JavaScript and HTML5, not Java (2 completely different things as others have said), I have a few pointers to give:
1. Replace that 1st line to <!DOCTYPE html>, You need to be in the HTML5 party, not the obsolete HTML4 with the long DOCTYPE.
2. Put the script to the bottom of the <body> instead of placing it inside <head>. that way all of your elements loads before the script executes. Example:
<!DOCTYPE html>
<head>
  <title>Woot a Title!!!</title>
  <style>
    p {
      color: #00F;
  </style>
</head>
<body>
  <p>Yeah I am blue!</p>
  <script>
    (function() {
      alert('Yeah I loaded all of the elements!');
  </script>
</body>
3. Let me fix that script up for you:
  (function() {
    const DELAY = 3000; // In milliseconds
    var urls = ['url1', 'url2', 'url3']; // Stick as many URL's here as you want
    var multiplier = 10 * (urls.length / (urls.length % 10)); // So you can have as many URL's as you want.
    // select a random page
    var num = Math.floor(Math.random() * multiplier) % urls.length;
    var selection = urls[num];
    // replace the page after DELAY
    setTimeout(function() {
      location.replace(selection);
    }, DELAY);
</script>
4. Really? You want pages to redirect to each other once in every whatever milliseconds? Talk about wasting bandwidth and data. I can provide another solution to that if you like.
That one smart guy.
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8969689
<!DOCTYPE html>
<head>
  <style>
    p {
      color: #00F;
  </style>
</head>
<body>
  <script>
    (function() {
  </script>
</body>
  (function() {
    }, DELAY);
</script>
another solution being iframes right? Right.....
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8971482
I was thinking of using div elements with CSS3 and have a pleasant loading screen so the computer can load the entire site before the user gets to the site (load once, be done with it) instead of having to download an entire page every however much delay.
There are good use case scenarios for iframes (Google Maps for example) but, this is not one of them. Using them here would make me cringe.
That one smart guy.
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8972556
I was joking lol this is how I would do it too have all the content there but hidden then use JS to change what is visable.
https://linustechtips.com/topic/701195-need-a-delay-java/#findComment-8972602
