*NOT URGENT* Just need to bash heads with GTX 970 "issue" with another techie.
So you mentioned "its not in the first DIMM", are you meaning it isn't in the top PCIE slot?.
If so I would recommend possibly trying a PCIE cable going from the top PCIE slot to the GPU, don't even have to mount it properly if you're just testing (although make sure you aren't sitting it on anything conductive of course).
If it runs a lot better then bobs your uncle you have found the issue.
Also a lot of people have reported issues with the new nvidia driver, I havent even updated to it and get 86fps @ 1440p on my 980ti so I would recommend a driver rollback if you've updated just to try it out.
On top of that also check your PSU and make sure you're getting enough power to your system (I assume it is if your performance went up with your recent power settings change).
The other option is checking gpu-z to make sure your GPU is running at the full PCIE 3.0/3.1 @ 16x (you will see this on the right hand side of the application.
Failing the above things, I would check other system resources and of course making sure the scaling in bf1 is at 42% as that is 100% of the set resolution (I know I know....it makes no sense).
