Was playing the decision last night at Beyoncé ultra at 80 fps
switched to medium just for jokes to see how bad it would be
and there was litterly no different apart from my fps at 170 lol
ibtrued it with all my games after that
and now personally think ultra is overrated
I can tell a single difference past high
what do u guys think ???
ultra overrated ???
please try it and see what u think
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/644781-ultra-settings-a-joke/
alot of the higher settings is the post processing of the small details, like hair effects, view distance, grass, water, slightly lower texture resolution etc... it really can be difficult to tell in some games and more in others when you turn the settings down and tweak them up to crank the FPS.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301079
AA?
Cutscenes?
Render distance?
Ram usage?
Upclose texture detail?
Fog?
Particles?
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301082
Often the difference between the highest settings is minimal. It's buying the most expensive GPU over the one below that, it makes less difference than the lowest end two GPU's.
(also, nice autocorrect on the first sentence)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301084
Have u not played the decision ?
;p
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301095
;p
Nope, but was mostly talking about the "Beyoncé" part I think.
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301101
3 minutes ago, themctipers said:
AA?
Cutscenes?
Render distance?
Ram usage?
Fog?
Particles?
Ye ok render difference is one u can tell
but really the detail is so small at 1440p
its just in distinguishable
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301104
1440p
try to run it on a native 1080p display at 1080p and try. See if there's AA going on or something
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301107
2 minutes ago, themctipers said:
1440p
I have a 1440p monitor tho so it is native
1080p pixel size bothers me some what
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301121
In some games like GTA V, you can notice some difference if you turn on the advanced settings, shadows render even further away, but if you turn that setting off, shadow only render when you are close... Although shadow still render when you are relatively close to them.
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301124
I'm with y'all on render distance but
like image quality that shit looks all the same to me
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301132
Yeah, it's more or less the same, some shadows settings (different from the one I've mentioned above) change A LOT, like, night and day for me (Medium vs high). Everything else (most of it) is just a 'because I can' thing.
Tablet: iPad Mini 2
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301146
Litterly just because I can il play at ultra but I have no reason too
this effects my next upgrade choice
and just basically doubled the life time of my Gpus tho
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301157
In many games the visual difference between high/very high or ultra (everything maxed) is barely noticeable unless you know what to look for.
It's also a mentality thing. Some people just feel better knowing they can turn everything to the max and still play at over 60fps.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301176
Its just game dependent. Sometimes all the extra settings get you are refinements on existing effects like softer shadows and maybe a bit better AA in motion. Othertimes its a completely different lighting system or vastly better antialiasing. It varies so much by game that its not something you can talk about generally.
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8301670
1 hour ago, App4that said:
And your last eye exam, was? xD
A few days ago
and I have a xb270hu in which I sit 2 feet from
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8302279
22 minutes ago, jjohnthedon1 said:
A few days ago
There's a pretty big disparity between a lot of the settings. You can argue if they are worth the fps investment, but not that the difference isn't there. But like I said, in a fast paced shooter you won't see them as fast paced shooters are not meant to be played in a way that has you noticing textures or clutter.
If anyone asks you never saw me.
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8302402
yes, it's all an elaborate troll that devs been pulling for so many years,
but you finally caught them, good job
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8302701
Makes sense tho !
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8302743
Makes sense tho !
gaming industry will go bankrupt now that you've revealed the scheme...
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8302763
6 minutes ago, App4that said:
I knew I liked you! xD
Ur both d**ks !
Haha
also (1600)
https://linustechtips.com/topic/644781-ultra-settings-a-joke/#findComment-8302822
