Arctic Water
B NEGATIVE
I see you're having a busy evening B Neg. :D
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
Love it so much :D
But if don't like the Cosmos 2 what is your favorite entusiast case? :)
Just wondering for future builds :)
Depends on the budget and whether you want to WC it.
I love the LD cases,Caselabs are also very nice if you like oversized.
At the moment,in the normal case division,Im a fan of the Air 540...something about that cube makes my man parts tingle....
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
While I really love my SMH10, I would love to do a build in a LD PC-V7.
To my eyes it has pretty much perfect proportions, phenomenal rad capacity
for its size and I really like how it looks in general.
BTW., been wondering: What's the build quality on LD cases, especially
the alu panel thickness? One of the things I like so much about Caselabs
is how sturdy they are, how do the LD cases compare to that in your opinion?
Thanks :) I was just wondering about the balls to the walls best case which ain't bigger then the Cosmos 2 and yes in my next build I will watercool :)
Cube cases are quite awesome but i am not really fan of well...the cube form  :unsure:
I would actually have loved to see a case which where formed like a a wider V :) Kind of like a W without the one in the middle :)
This way it could fit snuggly into a corner... :)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
The CL stuff is thicker Alu and i like the panel over frame design plus you can buy spares easily. Downside is that everything is an extra.
The LD case is cheaper for the EU buyers and is a solid design but has bolt on panels which can be a PITA.
Build quality is the same between them.
The LD stuff comes in more colours tho.
It a case of what catches your eye most really,nothing between them.
damn....just....damn.....copper and white, who knew it was such a winning combination.
damn
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
Good to know, thanks for the info! :)
From the photos I saw I've always been rather impressed with the paint
job on the LD, I just never found anything regarding material strength.
The panel over frame design is one of the things I like about CL as well,
though as you say it definitely does not drive prices down (and that's
besides all the extras one can/needs to buy, as you mention).
Ah well, can't have everything. I'll certainly be drooling over the V7
for quite a while, even though by the time I'd be able to afford another
build I'm not sure I could quite find a proper use for that case (it would
probably need to be another server with lots of HDD slots for future long
term expansion).
term expansion).
The powdercoat on the V8 is awesome,very flat,thick and even.
The CL S3 i have is in primer so i cant comment on the coating
Yeah that's what it looks like in pictures as well, really nice!
The coat on my SMH10 is very textured, if you rub your skin over
it, you will leave quite a bit of yourself on the case. :lol:
Personally I like how it looks, but I suppose some people might
prefer something less rough.
It is very resilient to mechanical damage though. While assembling
my case I slipped with the screw driver (just once, I promise :D ),
and it left barely a mark. I was really impressed. You can scratch
if of course (as you can any coat), but it does require significant
force.
Well thought out. One of the best i have ever seen so far.
A water-cooled mid-tier gaming PC.
Insane!
The first step to insanity is believing in your sanity.
wo
Wow! This looks really good. Love the colors.
The Crossfire Bridge actually matches something for once. haha
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 3x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
Wow this has to be one of the best systems that i have ever seen on the forum.
Corsair 350d, Asus Gryphon Z87, Intel i5 4670k 4.5 GHz, Corsair H100i, Corsair Vengence 16gb 1600 MHz,
AMD Radeon 260x, Corsair CX600, OCZ Vetex 450 128gb, Seagate 2 TB
the sleekness is jaw dropping. great work
Rig
CPU: 4770k @ 4.2GHz 1.15v | Mobo: ASUS z87 Sabertooth | Cooler: Corsair H110 | RAM: Vengeance 32GB DDR3 @ 1600MHz | GPU: GIGABYTE G1 GTX 1070 | Storage: Samsung 840 series 250GB SSD, Seagate 2TB SSHD, Seagate 4.25TB HDD | PSU: Corsair AX850 80+ gold modu | Case: Corsair 650d | Keyboard: Corsair K65 RGB Cherry MX Reds & a Leopold 210TP Numberpad Cherry MX Blues | Mouse: Logitech G502, DECHANIC desk mat | Monitor: 2x Dell IPS 23" S2340m & ASUS 144hz 24" VG248QE | Speakers: CA-3602a | Headset: Steelseries Syberia v2 Frost Blue OS: Win 10 Pro
holy mother of god O_O
CPU: i5 4670k with Noctua C12P-SE14 GPU: Gigabyte GTX 770 SSD: 250gb Samsung EVO MOBO: MSI Z87-G43 RAM: 8GB G-Skill 1600mhz PSU: Antec HCG 620W CASE: Corsair 300R windowed
I first looked at the heading for the build name Artic Water and thought some dummy named his case the same name as B negatives awesome build! ha ha Ohh it's you! Welcome to the copper channel! We worship copper work here! Always Inspiring.
God Damn! That.... Is.... Heavenly!! :wub:
I bought the Cosmos 2, after seeing this I'm glad that you can do so much in it.
Fantastic Build man!!! Good Job!
dat pipe doe! is just perfect
this is one of the greatest thing that has happened to me recently, and it happened on this forum, those involved have my eternal gratitude http://linustechtips.com/main/topic/198850-update-alex-got-his-moto-g2-lets-get-a-moto-g-for-alexgoeshigh-unofficial/ :')
i use to have the second best link in the world here, but it died ;_; its a 404 now but it will always be here
Why thanks,thats a hell of a compliment. ;)
Thanking you Sir.
xD
Thanks! :)
A-M-A-Z-I-N-G!!!!!!!!
Any build log videos on youtube??? I would watch the shit out of it lol
Sadly not,im not  a you tube video kind of guy but im being pressured into it...........slowly
:ph34r:
Copper  :wub:
Lots and lots of it :wub:
Jaw Dropping build ! <3
Great stuff,i have other logs on here too.
Always good to see you onevoicewild,your 900d isnt too shabby either! ;)
Thanks to as well! B)
Dat pipe tho....too long to polish....
:D
