Need and upgrade?
CruxYo
I want to know if I should upgrade my psu and I want to know which brands manufacture reliable power supplies (good clean power, good components, durable, etc.). I have a 550w made by XFX, I got a i7 4790k and I want to upgrade to 1080.
Should be fine as long as it´s not a XFX XT.
550w is enough depending on the rest of your system and any cpu overclock you might have, if you're looking into a new unit use this chart.
"The of and to a in is I that it for you was with on as have but be they"
550w should be good and XFX make great power supplies.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
550W should be fine - as long as it's not XFX XT you are good.
This list is bad and nobody should use it
Just now, CruxYo said:
Its an XFX TS
then your fine!
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
I went to batteries+ and they told me to get a car battery they gave me an adapter, and now my pc is fully gas powered!
