Fan on top of a fan.
By
TheNaitsyrk
in Cooling
in Cooling
Solved by Enderman,
2 minutes ago, TheNaitsyrk said:I posted a picture, it's in one of the posts above. I have 2x Quiet Red Led Corsair 120mm fans.
its not on a radiator, so it will pretty much be useless there
if you dont mind the noise and you want the looks, then sure go ahead, nothing will be damaged or anything
Featured Topics
1
skayqz ·
Posted in Graphics Cards10 -
youself ·
Posted in Linux, macOS and Everything Not-Windows2 -
3
cornexiors ·
Posted in Networking3 -
2
2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
