Hello there
I have a Apevia X-Sniper2, which comes with a blue led MOLEX fan in the front.
Would I be able to buy an adapter to be able to hook it into my mobo, other wise, it would run directly from the PSU at full power (from what I read these stock fans are very lound at max)
Thanks
Callum
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/582453-stock-case-fan-problem/
Well its weird because there are only 2 wires from the connector to the fan, as if it is only designed to run at full power, Meaning the motor and LED's are wired in series, meaning if I decreased power to fan, the lights would dim.
Roses are red
My name is Roy
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7607335
1 hour ago, narrdarr said:
well yeah most cheap fans are like that. so.... no matter what you go about do this. lower speed = dimmer light.
Do you know of a model of LED fans that won't dim its light according to its voltage input?
I'm looking for fans that do full LED when on and only turn off when the fan is off. Is that possible?
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7607777
I haven't looked into it much lately, but bitfenix makes one that you can hook up to their fan and led controller.
Or if you want to do something custom just find a led fan that uses a diode to send power to fan and led at the same time. remove the diode and add a 12v wire directly to the led line( and of course ground it.) if you want to be able to turn the led on/off put a switch on the 12v lead or if you want to make it fade use a turn dial switch to reduce the voltage input.
there is a somewhat older video on this, but its pretty easy.
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7609071
That's really cool. Electronics are very interesting.
Computer Specs:
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7609126
There are some LED fans which have separated power connectors for fan  and LED.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7609293
14 hours ago, UberGamerKing said:
Every single PWM LED fan can be controlled without dimming the LED's. I think even 3 pin fans have that feature
Idk about PWM. That might well be true. But 3pins are voltage controlled and LED uses same power with fan. So if you limit power for fan, you limit power to LED as well.
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7618931
Nah bruh
3pin fans have a variable resistor build into them, so 2 of the pins and positive and negative, while the 3rd wire/pin controls the resistance going into the motor.
This means the LED's are always receiving full power while the motor is being controlled in a parallel circuit
Roses are red
My name is Roy
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7620618
13 hours ago, UberGamerKing said:
Nah bruh
You need to quote me if this was intended as reply. And I'm not sure if we are talking about same kinda 3pin fans here. In the normal 3pins 3rd wire is rpm sensor. I know there's fans with dedicated power connector for LED with two connected pins (pwr and gnd ). I would appreciate if you can link to pic of actual motor to prove me wrong.
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7623786
This is the standard of fans in England. I moved to Seattle and of ll things, I wouldn't have thought the way 3pin pc fans work would be different.
The red box is surrounding the variable resistor in one of my fans.
Roses are red
My name is Roy
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7625263
Fine. But we do agree that it takes power from PWR wire and not rpm sensor, right? Or does that fan not have rpm sensor.
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7625812
I agree it takes power from PWR, but the variable resistor is controlled by the 3rd wire. In 4 pins, the 4th wire is the rpm sensor
Roses are red
My name is Roy
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7628310
Weird. I would think people want rpm sensor prior to LEDs being bright all the time. Since mobo can't control speed without it. And that there isn't any PWM LED fans. And that mobo pins don't correlate to those fans.
https://linustechtips.com/topic/582453-stock-case-fan-problem/#findComment-7628765
