HP Omen Clock Speed Problems 860m
Solved by BMARX123,
Problem solved apparently. HP's stupid smart adapter. Seems that the aftermarket charger I am using made the laptop think it was underpowered. Seems to be fixed now.
Featured Topics
LLENNxP90 ·
Gat Pelsinger ·
Posted in Laptops and Pre-Built Systems1 -
Mumintroll ·
Posted in Windows3 -
mr.happy ·
Posted in Power Supplies6 -
5
300DaysToGTA6 ·
Posted in Storage Devices5 -
5
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
