Confused about what to do after Building pc
If you dont need tp update your bios simply dont!
Drivers basically just go to the nvidia site and downloaded the latest for your gtx 3060ti. The rest will come automaticaly through windows update.
Use the nvidia site as colorfull will only have the launch driver and thats basically it.
Leave all the rest to windows it will figure it out.
What you will want to do in bios is set your ram at the correct speed.
Usually it will be running at 2133mhz or 2666mhz as those are base default speeds. To enable the correct one set the XMP profile to the speed that your ram is rsted for. If the pc is unstable at that just go one step lower.
If no boot dont worry just let it sit for a minute it should revert. If not unplug the cmos battery, replug and try again.
Else well go to NINITE get the software you want and start gamin!
Fyi I recommend firefox + ublock origin for a 99.999999% adfree web browsing experience without a hitch as firefox is basically one of the last true ad block able browsers. Its also quite light to run!
