Building NAS and need Opinion
AoGeko
Hey guys, currently building a NAS for my business and looking for some of your help. I'm currently looking for a case for this build and wondering if you guys can help.
Also if you guys want to help suggest other components for this build is very helpful.
Use of this NAS is to help store information such as documents files and soon to also store surveillance camera footage, but primarily used for document storage for a healthcare facility
PartPicker: http://pcpartpicker.com/p/9vFsyc
With only 2x 2tb hdds, you definitely dont need that much CPU processing power. Here is a nas build that I use for clients. You can load a piece of nas software called xpenology. It's basically the synology dsm software with a modded kernel to support basically any hardware.
My native language is C++
Were you going to provide a link? Thank you for the reply!
purple hdds are made for camera feed
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[i7-7700k@5Ghz | MSI Z270 M7 | 16GB 3000 GEIL EVOX | STRIX ROG 1060 OC 6G | EVGA G2 650W | ROSEWILL B2 SPIRIT | SANDISK 256GB M2 | 4x 1TB Seagate Barracudas RAID 10 ]
[i3-4360 | mini-itx potato | 4gb DDR3-1600 | 8tb wd red | 250gb seagate| Debian 9 ]
[Dell Inspiron 15 5567]
For general file storage and surveillance storage, the CPU isn't necessary. An i3 could do the job just fine.
got it thank you
this isnt primarily for surveillance.
That's a secondary use. WD Reds are designed for NAS and RAID operation with multiple users hitting the drives at once. They'll cope better with surveillance loads than Purples would with RAID and NAS operation.
An i3 should be enough for your needs.
Magical Pineapples
with stock cooler is also good enough
all your savings could go into more storage..., or just not spending it...
2017 Macbook Pro 15 inch
Yes ... the stock fan is not that loud and should be overkill for a I3.
Magical Pineapples
What about this ? G3258
Umm if you want to add more drives or run different plugins such as plex or servers you should get i3 as it will last you much longer.
Magical Pineapples
2 hours ago, AoGeko said:
thanks alot i think i might use this but i want to change the mother board to support at least 4 sata 3 ports
Get a Supermicro X10SLL-F-O.
PCPartPicker part list: http://pcpartpicker.com/p/GhBH6h
Price breakdown by merchant: http://pcpartpicker.com/p/GhBH6h/by_merchant/
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($114.99 @ Newegg)
Motherboard: Supermicro X10SLL-F Micro ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Memory: Crucial 8GB (1 x 8GB) DDR3-1866 Memory  ($54.99 @ Newegg)
Total: $309.97
Generated by PCPartPicker 2016-02-27 23:36 EST-0500
P.s. Most (if not all) C222, C224, and C226 boards require Unbuffered ECC memory. The memory you linked in your build is Registered (that's not compatible).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
